[Qgis-user] Warning and errors netcdf when running a command
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Mar 14 23:25:25 PDT 2024
> Langers, Fransje fransje.langers at wur.nl
> Thu Mar 14 23:01:45 PDT 2024
> ERROR 1: C:/Users/#/AppData/Local/Temp/processing_DbfCYS/1a30206c31d84010bc9572e8adfb0139/OUTPUT.nc, band 1: IReadBlock failed at X offset 0, Y offset 0: netCDF chunk fetch failed: #-39 (NetCDF: Operation not allowed in define mode)
Hi Fransje,
it looks like the issue is very likely due to the fact that the "Default
output raster layer extension" (in
Settings->Options->Processing->General) has been set to the value "nc"
(i.e. "netCDF" format").
May you check? If it is the case, have you set such option for a reason
or haven't you set it? If the latter, the you can fix the issue just
setting the "Default output raster layer extension" to the "tif" (i.e.
GeoTIFF) value, which is the default value for such option.
Best regards.
Andrea
More information about the QGIS-User
