[Qgis-user] Georeferencing Raster
Bodamer, Christian Christian.Bodamer at autobahn.de
Mon Mar 18 00:28:41 PDT 2024
Hello Michaela,
sometimes I have the same problem with PDF files. In such cases I change PDF to TIFF or png etc. with 150 dpi.
Best regards,
Christian
Die Autobahn GmbH des Bundes
Niederlassung Ost
Magdeburger Straße 51 · 06112 Halle
Christian Bodamer
Landschaftsplaner Verwaltung A- und E-Flächen
M +49 1525 76 54 493
T + 49 345 9409 9459
http://www.autobahn.de/
-----Ursprüngliche Nachricht-----
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von qgis-user-request at lists.osgeo.org
Gesendet: Freitag, 15. März 2024 11:17
An: qgis-user at lists.osgeo.org
Betreff: QGIS-User Digest, Vol 217, Issue 38
VORSICHT: Externe E-Mail! Klicken Sie nicht auf Links oder Anhänge, wenn Sie nicht von der Echtheit der Nachricht überzeugt sind.
Send QGIS-User mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of QGIS-User digest..."
Today's Topics:
   1. Warning and errors netcdf when running a command
      (Langers, Fransje)
   2. Re: Warning and errors netcdf when running a command
      (Andrea Giudiceandrea)
   3. Georeferencing Raster (Huesmann, Michaela)
   4. Re: Warning and errors netcdf when running a command
      (Langers, Fransje)
   5. Re: Warning and errors netcdf when running a command
   6. Re: Warning and errors netcdf when running a command
      (Langers, Fransje)
Message: 1
Date: Fri, 15 Mar 2024 06:01:45 +0000
From: "Langers, Fransje" <fransje.langers at wur.nl>
To: "QGIS-User at lists.osgeo.org" <QGIS-User at lists.osgeo.org>
Subject: [Qgis-user] Warning and errors netcdf when running a command
Message-ID:
        <AM9PR01MB8377758B6BF5F942ED0D74B68F282 at AM9PR01MB8377.eurprd01.prod.exchangelabs.com>
Content-Type: text/plain; charset="us-ascii"
Subject: Warning
I've used QGIS (version 3.34.3) for a few weeks now.
When I want to use a command from the toolbox processing (e.g. rasterize) I get the following warning: 'projection name Oblique_Stereographic in not part of the CF standard, will not be supported by CF! '
Followed by a number of errors:
ERROR 1: netcdf error #-62 : NetCDF: One or more variable sizes violate format constraints .
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::SetDefineMode,3039)
ERROR 1: netCDF chunk fetch failed: #-39 (NetCDF: Operation not allowed in define mode) ERROR 1: C:/Users/#/AppData/Local/Temp/processing_DbfCYS/1a30206c31d84010bc9572e8adfb0139/OUTPUT.nc, band 1: IReadBlock failed at X offset 0, Y offset 0: netCDF chunk fetch failed: #-39 (NetCDF: Operation not allowed in define mode) ERROR 1: netcdf error #-39 : NetCDF: Operation not allowed in define mode .
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::AddProjectionVars,6738)
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::AddProjectionVars,6743)
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::Close,2998)
I also get this warning when I use other commands.
Before, I could run these commands without getting these warning and errors. What do the warning and errors mean, and how can I fix it?
Best wishes
Fransje
Wageningen Environmental Research (WENR) Fransje Langers Onderzoeker Mens & Natuur Team Regionale Ontwikkeling en Ruimtegebruik (ROR) Environmental Sciences Group Wageningen University & Research (WUR) Postbus 47, 6700 AA, Wageningen Wageningen Campus, Gebouw 101 (Gaia), Kamer B.217 Droevendaalsesteeg 3, 6708 PB, Wageningen Tel. 0317 481677 (ma, di en do) [cid:image002.png at 01DA76A6.A3D4EC60]
http://www.wur.nl/environmental-research<http://www.wur.nl/environmental-research>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240315/e9dd50c4/attachment-0001.htm>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240315/e9dd50c4/attachment-0001.png>
Message: 2
Date: Fri, 15 Mar 2024 07:25:25 +0100
From: Andrea Giudiceandrea <andreaerdna at libero.it>
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Warning and errors netcdf when running a
        command
Message-ID: <438621a1-2300-4143-bd65-ccee0cfe1f63 at libero.it>
Content-Type: text/plain; charset=UTF-8; format=flowed
> Langers, Fransje fransje.langers at wur.nl Thu Mar 14 23:01:45 PDT
> 2024 ERROR 1:
Hi Fransje,
it looks like the issue is very likely due to the fact that the "Default output raster layer extension" (in
Settings->Options->Processing->General) has been set to the value "nc"
(i.e. "netCDF" format").
May you check? If it is the case, have you set such option for a reason or haven't you set it? If the latter, the you can fix the issue just setting the "Default output raster layer extension" to the "tif" (i.e.
GeoTIFF) value, which is the default value for such option.
Best regards.
Andrea
Message: 3
Date: Fri, 15 Mar 2024 07:03:32 +0000
From: "Huesmann, Michaela" <michaela.huesmann at Stadt-Steinfurt.de>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Georeferencing Raster
Message-ID: <77500f54d9bb4515a69f646d86a9df3b at Stadt-Steinfurt.de>
Content-Type: text/plain; charset="utf-8"
Hello all,
my collegue got some trouble with georeferencing raster images. As soon as he activates the tool  ?LAYER >> GEOREFERENCING? his system gets very, very sloooow. It takes plenty of time even to open the raster image and then to set referencing points. While changing the windows between Map and Referencing Tool the windows are getting grey and show ?No response?. In the end he doesn?t know wheter the system is still running or ?died? along the way.
I installed QGIS Version 3.34.4 now, but it ist he same behaviour as in hil older version 3.16.
Is there maybe a special setting, that can be changed to get a better performance?
Best regards, Michaela
[Kreisstadt Steinfurt]<http://www.steinfurt.de/>
 - 48565 Steinfurt
http://www.steinfurt.de/<http://www.steinfurt.de/>
Mit freundlichen Gr??en
im Auftrag
Michaela Huesmann
Geodaten
Fachdienst Tiefbau
Tel.: +49 2552 925 219
Fax:
E-Mail: michaela.huesmann at Stadt-Steinfurt.de<mailto:michaela.huesmann at Stadt-Steinfurt.de>
Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240315/edd54ab5/attachment-0001.htm>
Type: image/jpeg
Desc: image4fbc9b.JPG
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240315/edd54ab5/attachment-0001.jpe>
Message: 4
Date: Fri, 15 Mar 2024 08:05:24 +0000
        command
Message-ID:
        <AM9PR01MB83779A75E72A759199D86E1B8F282 at AM9PR01MB8377.eurprd01.prod.exchangelabs.com>
Dear Andrea,
This was indeed the situation. Thanks for solving my problem!
Message: 5
Date: Fri, 15 Mar 2024 11:13:59 +0100
Cc: fransje.langers at wur.nl
        command
Message-ID: <908d30c1-f676-443f-b1d1-dce5ee2be1f9 at libero.it>
> Langers, Fransje fransje.langers at wur.nl Fri Mar 15 01:05:24 PDT
> 2024
You are welcome. I suggest you to also ensure that the "Default output vector layer extension" is set to the value "gpkg" (GeoPackage), since I guess it is probably also incorrectly set to the "xtf" value which will also lead to issues with the GDAL processing algorithms having vector layer as output.
Since I suppose you have not intentionally set such options (like many other users experiencing similar issues), it would be very useful if you could remember what have you done after the last time the algorithm worked without issues and the first time it didn't work: have you upgraded / downgraded QGIS, or installed / uninstalled any plugin or used an older version and a newer version of QGIS with the same QGIS user profile, or...?
Every detail would help to find the root cause of the issue and try to permanently fix it.
Best regards.
Andrea
Message: 6
Date: Fri, 15 Mar 2024 10:17:14 +0000
        command
Message-ID:
        <AM9PR01MB8377B6ACEF36B25B94601C868F282 at AM9PR01MB8377.eurprd01.prod.exchangelabs.com>
I will check that too! I had a QGIS course last week, where we changed some settings. I think I made a change too many.
-----Original Message-----
Sent: vrijdag 15 maart 2024 11:14
Cc: Langers, Fransje <fransje.langers at wur.nl>
Subject: Re: [Qgis-user] Warning and errors netcdf when running a command
> 2024
Best regards.
Andrea
Subject: Digest Footer
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
End of QGIS-User Digest, Vol 217, Issue 38
+++ Verkehrsmeldungen und alles rund um die Autobahn finden Sie in unserer App: Autobahn.de/app<https://www.autobahn.de/app> +++
Rechtsform: GmbH
Sitz: Heidestraße 15 · 10557 Berlin · AG Charlottenburg · HRB 200131 B
Geschäftsführung: Dr. Michael Güntner (Vorsitzender),
Dirk Brandenburger
Aufsichtsratsvorsitzender: Oliver Luksic
Vertraulichkeitshinweis
Diese Nachricht und jeder etwaig uebermittelte Anhang beinhalten vertrauliche Informationen und sind nur fuer die Personen oder Unternehmen bestimmt, an welche sie tatsaechlich gerichtet sind. Sollten Sie nicht der bestimmungsgemaesse Empfaenger sein, weisen wir Sie darauf hin, dass die Verbreitung, das (auch teilweise) Kopieren sowie der Gebrauch der empfangenen E-Mail und der darin enthaltenen Informationen verboten sind und gegebenenfalls Schadensersatzpflichten ausloesen können. Sollten Sie diese Nachricht aufgrund eines Uebermittlungsfehlers erhalten haben, bitten wir Sie, den Absender unverzueglich hiervon in Kenntnis zu setzen.
Sicherheitswarnung: Bitte beachten Sie, dass das Internet kein sicheres Kommunikationsmedium ist. Obwohl wir im Rahmen unseres Qualitaetsmanagements und der gebotenen Sorgfalt Schritte eingeleitet haben, um einen Computervirenbefall weitestgehend zu verhindern, koennen wir wegen der Natur des Internet das Risiko eines Computervirenbefalls dieser E-Mail nicht ausschliessen.
Confidentiality note
This notice and any attachments which are transmitted contain confidential information and are intended only for the persons or companies to whom they are actually addressed. If you are not the intended recipient, please note that the distribution, copying (even partial) and use of the received e-mail and the information contained in the e-mail are prohibited and may result in a possible liability for damages. Should you have received this message due to a transmission error, we ask you to inform the sender immediately.
Safety warning: Please note that the Internet is not a safe means of communication or form of media. Although we are continuously increasing our due care of preventing virus attacks as a part of our Quality Management, we are not able to fully prevent virus attacks as a result of the nature of the Internet.
Hinweis zur Datenverarbeitung / Link to data protection policy: https://www.autobahn.de/datenschutz
More information about the QGIS-User mailing list
