[Qgis-user] Georeferencing Raster
Patrick Dunford enzedrailmaps at gmail.com
Mon Mar 18 04:57:31 PDT 2024
When you are replying to a digest, kindly observe standard netiquette
and only quote the part of the digest message that is relevant to the
discussion.
Any activity that involves processing raster images is by definition
much more resource intensive than editing vector layers. When you are
drawing maps, most of the layers you are likely to be working with are
vectors. It is inevitable your system will be much more impacted in
performance when processing the raster data than it is for drawing
vector layers. The onus is basically on you to ensure you are using a
computer system that has good performance specifications.
On 18/03/24 20:28, Bodamer, Christian via QGIS-User wrote:
> Hello Michaela,
> sometimes I have the same problem with PDF files. In such cases I change PDF to TIFF or png etc. with 150 dpi.
> Best regards,
> Christian
> Die Autobahn GmbH des Bundes
> Niederlassung Ost
> Magdeburger Straße 51 · 06112 Halle
> Christian Bodamer
> Landschaftsplaner Verwaltung A- und E-Flächen
> M +49 1525 76 54 493
> T + 49 345 9409 9459
> Christian.Bodamer at autobahn.de
> http://www.autobahn.de/
> Message: 3
> Date: Fri, 15 Mar 2024 07:03:32 +0000
> From: "Huesmann, Michaela" <michaela.huesmann at Stadt-Steinfurt.de>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Georeferencing Raster
> Message-ID: <77500f54d9bb4515a69f646d86a9df3b at Stadt-Steinfurt.de>
> Content-Type: text/plain; charset="utf-8"
> Hello all,
> my collegue got some trouble with georeferencing raster images. As soon as he activates the tool  ?LAYER >> GEOREFERENCING? his system gets very, very sloooow. It takes plenty of time even to open the raster image and then to set referencing points. While changing the windows between Map and Referencing Tool the windows are getting grey and show ?No response?. In the end he doesn?t know wheter the system is still running or ?died? along the way.
> I installed QGIS Version 3.34.4 now, but it ist he same behaviour as in hil older version 3.16.
> Is there maybe a special setting, that can be changed to get a better performance?
> Best regards, Michaela
> [Kreisstadt Steinfurt]<http://www.steinfurt.de/>
>   - 48565 Steinfurt
More information about the QGIS-User mailing list
