[QGIS-ZA-user] QGIS Legend Problem
Dean Ollis dean.ollis at gmail.com
Mon Jul 17 05:45:11 PDT 2017
Hi, Immo
Could you send us a copy of the layer you are trying to render with a
legend, or a clipped section of the layer? That will help with the
testing...
Thanks
Dean
Dean Ollis
Freshwater Research Centre
Kommetjie, Cape Town
CELL: 072 377 7006
-------- Original Message --------
Subject: Re: [QGIS-ZA-user] QGIS Legend Problem
From: Immo Blecher via qgis-za-user <qgis-za-user at lists.osgeo.org>
To: South Africa QGIS user group <qgis-za-user at lists.osgeo.org>
Cc: Immo Blecher <immob19 at gmail.com>
Date: 17/07/2017 14:23
> Sorry Frank, I realised later that I did not send that info. Here it is:
> QGIS version
> 2.18.10
> QGIS code revision
> 59e0f78 <https://github.com/qgis/QGIS/commit/59e0f78>
> Compiled against Qt
> 4.8.7
> Running against Qt
> 4.8.7
> Compiled against GDAL/OGR
> 1.11.3
> Running against GDAL/OGR
> 1.11.3
> Compiled against GEOS
> 3.5.0-CAPI-1.9.0
> Running against GEOS
> 3.5.0-CAPI-1.9.0 r4084
> PostgreSQL Client Version
> 9.5.2
> SpatiaLite Version
> 4.3.0a
> QWT Version
> 5.2.3
> PROJ.4 Version
> 492
> QScintilla2 Version
> 2.9.1
> And I run it under Ubuntu 16.04 LTS
> Thanks
> Immo
> On 17/07/2017 14:19, Frank Sokolic via qgis-za-user wrote:
>> Hi Immo,
>> Which version of QGIS are you using?
>> Frank.
>> On 17/07/2017 09:48, Immo Blecher via qgis-za-user wrote:
>>> Good Morning Everyone,
>>> I have a geology layer with a few columns, including the
>>> chronostratigraphic symbol, the rock type description and,
>>> importantly, a colour column (String type). The values stored in the
>>> colour column are the HTML hex values for the colour according to
>>> the 1 : 1 000 000 simplified geological map of South Africa.
>>> When I open the layer and select the colour column for colouring the
>>> lithological units it works beautifully, but I do not get a legend
>>> for the composer. But if I set the Properties|Style to Categorized
>>> and then again select the colour from the Colour column in the table
>>> I also get the same nicely coloured map according to the colour
>>> column, an a Legend. But the Legend is wrong...it chooses random
>>> colours! What am I doing wrong? Is there a way to get a correct
>>> legend, also only showing the units which are actually on the map in
>>> the composer. I can set the colours manually to match the value in
>>> the colour field but that sort of defeats the purpose.
>>> Thanks for your help so long,
>>> Immo
>>> *Immo F. Blecher**Street: */52 Lynedoch Eco Village, Lynedoch, 7603,
>>> South Africa //*Postal:*//52 Lynedoch Eco Village, Lynedoch, 7603,
>>> South Africa //*Cell:*///+27 83 272 6791 |*Fax: *+27 86 7363302
>>> *Email:*_immo at blecher.co.za_ <mailto:immo at blecher.co.za> |
>>> _immob19 at gmail.com_ <mailto:immob19 at gmail.com>|
>>> _immob at mymtnmail.co.za <mailto:immob at mymtnmail.co.za>
>>> _*Internet:*_http://www.blecher.co.za/_
>>> qgis-za-user mailing list
>>> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
> _immob19 at gmail.com_ <mailto:immob19 at gmail.com>| _immob at mymtnmail.co.za
> <mailto:immob at mymtnmail.co.za> _*Internet:*_http://www.blecher.co.za/_
> Contact me: immob19 at gmail.com immoblecher
> <http://www.linkedin.com/pub/immo-blecher/30/414/b8>
> Please consider your environmental responsibility. Before printing
> this e-mail message, ask yourself whether you really need a hard copy.
> IMPORTANT: The contents of this email and any attachments are
> confidential. They are intended for the named recipient(s) only. If
> you have received this email by mistake, please notify the sender
> immediately and do not disclose the contents to anyone or make copies
> thereof.
More information about the qgis-za-user mailing list
