[QGIS-ZA-user] QGIS Legend Problem
Immo Blecher immob19 at gmail.com
Mon Jul 17 06:03:08 PDT 2017
Hi Dean,
Attached the Lithology Spatialite file with some of the lithologies in
the Lithology Layer. With the whole South Africa the file would be too
large to email.
Immo
On 17/07/2017 14:45, Dean Ollis via qgis-za-user wrote:
> Hi, Immo
> Could you send us a copy of the layer you are trying to render with a
> legend, or a clipped section of the layer? That will help with the
> testing...
> Thanks
> Dean
> Dean Ollis
> Freshwater Research Centre
> Kommetjie, Cape Town
> CELL: 072 377 7006
> -------- Original Message --------
> Subject: Re: [QGIS-ZA-user] QGIS Legend Problem
> From: Immo Blecher via qgis-za-user <qgis-za-user at lists.osgeo.org>
> To: South Africa QGIS user group <qgis-za-user at lists.osgeo.org>
> Cc: Immo Blecher <immob19 at gmail.com>
> Date: 17/07/2017 14:23
>> Sorry Frank, I realised later that I did not send that info. Here it is:
>> QGIS version
>> 2.18.10
>> QGIS code revision
>> 59e0f78 <https://github.com/qgis/QGIS/commit/59e0f78>
>> Compiled against Qt
>> 4.8.7
>> Running against Qt
>> 4.8.7
>> Compiled against GDAL/OGR
>> 1.11.3
>> Running against GDAL/OGR
>> 1.11.3
>> Compiled against GEOS
>> 3.5.0-CAPI-1.9.0
>> Running against GEOS
>> 3.5.0-CAPI-1.9.0 r4084
>> PostgreSQL Client Version
>> 9.5.2
>> SpatiaLite Version
>> 4.3.0a
>> QWT Version
>> 5.2.3
>> PROJ.4 Version
>> 492
>> QScintilla2 Version
>> 2.9.1
>> And I run it under Ubuntu 16.04 LTS
>> Thanks
>> Immo
>> On 17/07/2017 14:19, Frank Sokolic via qgis-za-user wrote:
>>> Hi Immo,
>>> Which version of QGIS are you using?
>>> Frank.
>>> On 17/07/2017 09:48, Immo Blecher via qgis-za-user wrote:
>>>> Good Morning Everyone,
>>>> I have a geology layer with a few columns, including the
>>>> chronostratigraphic symbol, the rock type description and,
>>>> importantly, a colour column (String type). The values stored in
>>>> the colour column are the HTML hex values for the colour according
>>>> to the 1 : 1 000 000 simplified geological map of South Africa.
>>>> When I open the layer and select the colour column for colouring
>>>> the lithological units it works beautifully, but I do not get a
>>>> legend for the composer. But if I set the Properties|Style to
>>>> Categorized and then again select the colour from the Colour column
>>>> in the table I also get the same nicely coloured map according to
>>>> the colour column, an a Legend. But the Legend is wrong...it
>>>> chooses random colours! What am I doing wrong? Is there a way to
>>>> get a correct legend, also only showing the units which are
>>>> actually on the map in the composer. I can set the colours manually
>>>> to match the value in the colour field but that sort of defeats the
>>>> purpose.
>>>> Thanks for your help so long,
>>>> Immo
>>>> *Immo F. Blecher**Street: */52 Lynedoch Eco Village, Lynedoch,
>>>> 7603, South Africa //*Postal:*//52 Lynedoch Eco Village, Lynedoch,
>>>> 7603, South Africa //*Cell:*///+27 83 272 6791 |*Fax: *+27 86
>>>> 7363302 *Email:*_immo at blecher.co.za_ <mailto:immo at blecher.co.za> |
>>>> _immob19 at gmail.com_ <mailto:immob19 at gmail.com>|
>>>> _immob at mymtnmail.co.za <mailto:immob at mymtnmail.co.za>
>>>> _*Internet:*_http://www.blecher.co.za/_
>>>> _______________________________________________
>>>> qgis-za-user mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
>> *Immo F. Blecher**Street: */52 Lynedoch Eco Village, Lynedoch, 7603,
>> South Africa //*Postal:*//52 Lynedoch Eco Village, Lynedoch, 7603,
>> South Africa //*Cell:*///+27 83 272 6791 |*Fax: *+27 86 7363302
>> Contact me: immob19 at gmail.com immoblecher
>> <http://www.linkedin.com/pub/immo-blecher/30/414/b8>
>> Please consider your environmental responsibility. Before printing
>> this e-mail message, ask yourself whether you really need a hard copy.
>> IMPORTANT: The contents of this email and any attachments are
>> confidential. They are intended for the named recipient(s) only. If
>> you have received this email by mistake, please notify the sender
>> immediately and do not disclose the contents to anyone or make copies
>> thereof.
*Immo F. Blecher**
Street: */52 Lynedoch Eco Village, Lynedoch, 7603, South Africa
//*Postal:*//52 Lynedoch Eco Village, Lynedoch, 7603, South Africa
_immob19 at gmail.com_ <mailto:immob19 at gmail.com>| _immob at mymtnmail.co.za
Please consider your environmental responsibility. Before printing this
confidential. They are intended for the named recipient(s) only. If you
thereof.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170717/d4940aac/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170717/d4940aac/attachment-0001.obj>
More information about the qgis-za-user mailing list
