[STDM-dev] Refactor in stdm.data package references
John Gitau gkahiu at gmail.com
Sun Jan 10 13:27:33 PST 2016
Hi devs,
This is to inform you I have made changes with regard to how modules in the
*stdm.data* package are being referenced - rather than importing the
modules through the package as defined in __init__.py, I have refactored
all references to import the functions and classes directly from the
corresponding modules in *ref_config_mod* branch; for instance:
from stdm.data import spatial_tables
has now been refactored to
from stdm.data.pg_utils import spatial_tables
The reason is to enable proper importing of modules when writing tests,
which were initially failing.
Consequently, please ensure that you accept server changes pertaining to
stdm.data.* changes across the plugin in *ref_config_mod* branch and master
(eventually when merged).
Regards,
John
URL: <http://lists.osgeo.org/pipermail/stdm-dev/attachments/20160111/c54d3665/attachment.html>
More information about the STDM-dev mailing list
