[STDM-user] help: STDM stops when I try to generate report
maruyama idi05 at idi.or.jp
Wed Oct 12 16:49:29 PDT 2016
Dear Mr. Gitau,
Thank you very much for your advice.
Actually, I did not use Japanese character but use only English alphabet.
Is there any documents which describe procedure of using STDM more detailed
than the manual?
Best regards,
Maruyama
From: John Gitau [mailto:John.Gitau at unhabitat.org]
Sent: Friday, October 7, 2016 7:23 PM
To: maruyama <idi05 at idi.or.jp>
Cc: stdm-user at lists.osgeo.org
Subject: Re: [STDM-user] help: STDM stops when I try to generate report
Dear Maruyama,
The Report Builder does not handle non-ASCII characters such as Cyrillic,
acute accents and grave accents commonly found in latin characters, or in
your case, Japanese character types (kanji, kana etc.). However, one way of
working around it is using the Document Designer module. It gives you
greater flexibility in terms of designing document outputs including
aggregate reports and it supports UTF8 characters. Could you give this a
try?
Regards,
John Gitau
Land and GLTN Unit, Urban Legislation, Land and Governance Branch |
UN-HABITAT
NOF
Block 3 Level 3 South Wing I P.O. Box 30030-00100 Nairobi,
Kenya
Tel
: + 254 20 762 3032 | +254 (0)722 945 556
Website:www.unhabitat.org <http://www.unhabitat.org>  | Partners'
website:www.gltn.net <http://www.gltn.net>
-----"STDM-user" <stdm-user-bounces at lists.osgeo.org
<mailto:stdm-user-bounces at lists.osgeo.org> > wrote: -----
To: <stdm-user at lists.osgeo.org <mailto:stdm-user at lists.osgeo.org> >
Sent by: "STDM-user"
Date: 10/07/2016 12:41PM
Subject: [STDM-user] help: STDM stops when I try to generate report
Dear All,
I have encountered another problem.
When I tried to generate a report following 7.3 Generating Documents and
Reports of the manual starting from page 115,
I got the error message as attached file at the step 8 which is for
"Generate report".
I would be most grateful if you could tell me how to solve this problem.
With best regards,
Maruyama
P.S.  I use the following OS and STDM
OS: windows 10 pro
STDM 1.1 QGIS 2.8.3
Sent: Thursday, October 6, 2016 2:11 PM
To: 'stdm-user at lists.osgeo.org' <stdm-user at lists.osgeo.org
Subject: help: STDM stops when I try to set up "New Social Tenure
relationship"
Dear All,
I have just installed STDM 1.1 with QGIS 2.8.3.  I encountered the following
problem.
OS I am using is Windows 10 pro
When I came to set up "NEW Social Tenure Relationship" in page 67 of the
STDM user manual, inputting "WABALE" worked properly.
But after that , when I put "1000" for "Select the land or building
information", the message in the attached file appeared.
Before I came to this part, I imported "sample data.shp".  Because if not,
nothing happen when I put anything at step 7 in page 67.
I look forward to having any help from you.
With best regards,
Maruyama
STDM-user mailing list
STDM-user at lists.osgeo.org <mailto:STDM-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/stdm-user
[attachment "Gen_document&report.png" removed by John
Gitau/UNHABITAT/NBO/UNO]
URL: <http://lists.osgeo.org/pipermail/stdm-user/attachments/20161013/8dd79e5b/attachment.html>
More information about the STDM-user mailing list
