[STDM-user] help: STDM stops when I try to generate report
John Gitau John.Gitau at unhabitat.org
Fri Oct 7 03:22:31 PDT 2016
Dear Maruyama,
The Report Builder does not handle non-ASCII characters such as Cyrillic, acute accents and grave accents commonly found in latin characters, or in your case, Japanese character types (kanji, kana etc.). However, one way of working around it is using the Document Designer module. It gives you greater flexibility in terms of designing document outputs including aggregate reports and it supports UTF8 characters. Could you give this a try?
Regards,
John Gitau
Land and GLTN Unit, Urban Legislation, Land and Governance Branch | UN-HABITAT
NOF
 Block 3 Level 3 South Wing I P.O. Box 30030-00100 Nairobi,
Kenya
Tel
: + 254 20 762 3032 | +254 (0)722 945 556
Website:www.unhabitat.org | Partners' website:www.gltn.net
-----"STDM-user" <stdm-user-bounces at lists.osgeo.org> wrote: -----
To: <stdm-user at lists.osgeo.org>
Sent by: "STDM-user"
Date: 10/07/2016 12:41PM
Subject: [STDM-user] help: STDM stops when I try to generate report
Dear All,
I have encountered another problem.
When I tried to generate a report following 7.3 Generating Documents and Reports of the manual starting from page 115,
I got the error message as attached file at the step 8 which is for “Generate report”.
I would be most grateful if you could tell me how to solve this problem.
With best regards,
Maruyama
P.S.  I use the following OS and STDM
OS: windows 10 pro
STDM 1.1 QGIS 2.8.3
Sent: Thursday, October 6, 2016 2:11 PM
To: 'stdm-user at lists.osgeo.org' <stdm-user at lists.osgeo.org>
Subject: help: STDM stops when I try to set up "New Social Tenure relationship"
Dear All,
I have just installed STDM 1.1 with QGIS 2.8.3.  I encountered the following problem.
OS I am using is Windows 10 pro
When I came to set up “NEW Social Tenure Relationship” in page 67 of the STDM user manual, inputting “WABALE” worked properly.
But after that , when I put “1000” for “Select the land or building information”, the message in the attached file appeared.
Before I came to this part, I imported “sample data.shp”.  Because if not, nothing happen when I put anything at step 7 in page 67.
I look forward to having any help from you.
With best regards,
Maruyama
STDM-user mailing list
STDM-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/stdm-user
[attachment "Gen_document&report.png" removed by John Gitau/UNHABITAT/NBO/UNO]
URL: <http://lists.osgeo.org/pipermail/stdm-user/attachments/20161007/f76b9679/attachment.html>
More information about the STDM-user mailing list
