[STDM-user] help: STDM stops when I try to generate report
maruyama idi05 at idi.or.jp
Thu Oct 6 23:57:36 PDT 2016
Dear All,
I have encountered another problem.
When I tried to generate a report following 7.3 Generating Documents and
Reports of the manual starting from page 115,
I got the error message as attached file at the step 8 which is for
"Generate report".
I would be most grateful if you could tell me how to solve this problem.
With best regards,
Maruyama
P.S.  I use the following OS and STDM
OS: windows 10 pro
STDM 1.1 QGIS 2.8.3
Sent: Thursday, October 6, 2016 2:11 PM
To: 'stdm-user at lists.osgeo.org' <stdm-user at lists.osgeo.org>
Subject: help: STDM stops when I try to set up "New Social Tenure
relationship"
Dear All,
I have just installed STDM 1.1 with QGIS 2.8.3.  I encountered the following
problem.
OS I am using is Windows 10 pro
When I came to set up "NEW Social Tenure Relationship" in page 67 of the
STDM user manual, inputting "WABALE" worked properly.
But after that , when I put "1000" for "Select the land or building
information", the message in the attached file appeared.
Before I came to this part, I imported "sample data.shp".  Because if not,
nothing happen when I put anything at step 7 in page 67.
I look forward to having any help from you.
With best regards,
Maruyama
URL: <http://lists.osgeo.org/pipermail/stdm-user/attachments/20161007/54a1aadf/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/stdm-user/attachments/20161007/54a1aadf/attachment-0001.png>
More information about the STDM-user mailing list
