[ZOO-Discuss] ZOO OGR Demo
Gérald Fenoy gerald.fenoy at geolabs.fr
Thu Nov 12 04:03:46 PST 2009
Hi Guillaume,
as you can choose the DataInput type you could also use a specific
output format, you only have to describe what is e desired output
format you want (the same KVP syntax than the one used for DataInputs).
You'll find in the following some requests samples using KVP for GET
HTTP METHOD :
  * sample using the JSON as output in ResponseDocument :
   => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=application/json
  * sample using the GML geeometry section in ResponseDocument :
   => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/xml
  * sample using unsupported output format  (so the default output
will be used) :
   => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
So you could define what are the inputs type and what should be the
output one :)
Hope this was clear enough and answer you question.
Let me know,
regards,
Le 11 nov. 2009 à 22:04, Guillaume Sueur a écrit :
> is json chosen automatically from http user-agent then ? WPS is not
> only
> a browser service. so there should be a way to specify the desired
> output format.
> Le mercredi 11 novembre 2009 à 22:00 +0100, rldhont a écrit :
>> I think it's coll to use GML and have a JSON because GML sucks in a
>> browser.
>> Well it's my point of view.
>>> Cool !
>>> but as Eric mentionned previously, I don't understand either why a
>>> WFS/GML geometry for input gets a geojson for output. Nothing
>>> seems to
>>> specify it in the request. I think the format should be consistant
>>> between input and output unless requested different.
>>> Thanks  for your efforts in putting together this first demo.
>>> Regards
>>> Guillaume
>>> Le mercredi 11 novembre 2009 à 21:20 +0100, rldhont a écrit :
>>>> Hi all,
>>>> I'm glad to annonce a new version of ZOO OGR Demo :
>>>> http://demo.zoo-project.org/ogr/ogr-wfs-demo.html
>>>> This one is fully integrated with the ZOO project design and add
>>>> 1 new
>>>> capability : choose a distance for the buffer processing.
>>>> Enjoy!
>>>> René-Luc D'Hont
>>>> 3Liz
>>>> _______________________________________________
>>>> Zoo-discuss mailing list
>>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Gérald Fenoy
GEOLABS
Siège social :
Futur Building I
1280, avenue des Platanes
34970 Lattes
Tél. fixe : 04 67 53 67 37
Tél. portable : 06 70 08 25 39
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20091112/fcb6f6ff/attachment.html>
More information about the Zoo-discuss mailing list
