[ZOO-Discuss] ZOO OGR Demo
Gérald Fenoy gerald.fenoy at geolabs.fr
Thu Nov 12 04:09:31 PST 2009
I forgot to mention but it is obvious that you could choose also your
output format for RawDataOutput if needed.
Kind regards,
Le 12 nov. 2009 à 13:03, Gérald Fenoy a écrit :
> Hi Guillaume,
> as you can choose the DataInput type you could also use a specific
> output format, you only have to describe what is e desired output
> format you want (the same KVP syntax than the one used for
> DataInputs).
> You'll find in the following some requests samples using KVP for GET
> HTTP METHOD :
>  * sample using the JSON as output in ResponseDocument :
>   => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=application/json
>  * sample using the GML geeometry section in ResponseDocument :
>   => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/xml
>  * sample using unsupported output format  (so the default output
> will be used) :
>   => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
> So you could define what are the inputs type and what should be the
> output one :)
> Hope this was clear enough and answer you question.
> Let me know,
> regards,
> Le 11 nov. 2009 à 22:04, Guillaume Sueur a écrit :
>> is json chosen automatically from http user-agent then ? WPS is not
>> only
>> a browser service. so there should be a way to specify the desired
>> output format.
>> Le mercredi 11 novembre 2009 à 22:00 +0100, rldhont a écrit :
>>> I think it's coll to use GML and have a JSON because GML sucks in
>>> a browser.
>>> Well it's my point of view.
>>>> Cool !
>>>> but as Eric mentionned previously, I don't understand either why a
>>>> WFS/GML geometry for input gets a geojson for output. Nothing
>>>> seems to
>>>> specify it in the request. I think the format should be consistant
>>>> between input and output unless requested different.
>>>> Thanks  for your efforts in putting together this first demo.
>>>> Regards
>>>> Guillaume
>>>> Le mercredi 11 novembre 2009 à 21:20 +0100, rldhont a écrit :
>>>>> Hi all,
>>>>> I'm glad to annonce a new version of ZOO OGR Demo :
>>>>> http://demo.zoo-project.org/ogr/ogr-wfs-demo.html
>>>>> This one is fully integrated with the ZOO project design and add
>>>>> 1 new
>>>>> capability : choose a distance for the buffer processing.
>>>>> Enjoy!
>>>>> René-Luc D'Hont
>>>>> 3Liz
>>>>> _______________________________________________
>>>>> Zoo-discuss mailing list
>>>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> GEOLABS
> Siège social :
> Futur Building I
> 1280, avenue des Platanes
> 34970 Lattes
> Tél. fixe : 04 67 53 67 37
> Tél. portable : 06 70 08 25 39
Gérald Fenoy
GEOLABS
Siège social :
Futur Building I
34970 Lattes
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20091112/8ea0781e/attachment.html>
More information about the Zoo-discuss mailing list
