[ZOO-Discuss] Static libraries in ZOO (libcgic)?
Markus Neteler neteler at osgeo.org
Thu Nov 4 08:01:26 PDT 2010
Hi Gérald,
On Thu, Nov 4, 2010 at 2:28 PM, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> Hi Markus,
> my comments bellow,
> Le 4 nov. 2010 à 12:14, Markus Neteler a écrit :
> Hi,
> we are currently trying to install ZOO on Fedora14 but have the problem
> that libfcgi.a is used in
> http://zoo-project.org/trac/browser/trunk/thirds/cgic206/Makefile
> which doesn't exist at least since Fedora13.
> did you tried modifying the Makefile of cgi206 to use the FastCGI dynamic
> library ? I think this shall work.
Luca says that this works. He'll write more about this asap.
> I wonder why a static library
> is called here and why libcgic is generated as static library, too.
> I thought that dynamic libs (.so) are way more effective?
> In fact since the begining we try to make ZOO-Project as less intrusive as
> possible. I mean, if there is some program which depends on libcgic dynamic
> library and you remplace by our own copy I think that some things can be
> wrong. So we thought that it can be a good idea to avoid the use of dynamic
> library for the libcgic.
> About the FastCGI static library use, as we use libcgic as a static library,
> I thought that it can be good to get a dependency free library, I can be
> wrong.
Not wrong for sure :) It is a matter of (technical) choice.
> I agree that that dynamic libraries can make the final binary smaller in
> size but what is exactly the efficiency you're talking about, can you give
> me more details ?
Not too much - I was basically driven by the fact that the static lib no longer
exists... Years ago we turned GRASS from static to dynamic compilation, there
it was really relevant!
Cheers
Markus
More information about the Zoo-discuss mailing list
