[ZOO-Discuss] Is any documentation or examples regarding how to use Zoo API
nicolas bozon nicolas.bozon at gmail.com
Wed Nov 10 01:27:04 PST 2010
Hi list,
Thanks René-Luc for providing this information
I think we should move the effort to the wiki, as yes, doc is still missing
for the API
I've just added the Classes list you provided  to the ZOO API Examples page
http://zoo-project.org/trac/wiki/ZooWebSite/ZOOAPI/Examples
Best,
Nick
2010/11/10 rldhont <rldhont at gmail.com>
> Le 10/11/2010 09:49, Markus Neteler a écrit :
> > On Wed, Nov 10, 2010 at 1:15 AM, Yingqi Tang<anakintang at gmail.com>
>  wrote:
> >> Hi all,
> >> I am just wondering if there is any documentation or examples regarding
> how
> >> to use Zoo API? The FOSS4G pdf tutorial actually has a lot of good
> >> information and helps me successfully set up a running instance of Zoo
> >> kernel, there is very few information about using Zoo API to chain WPS
> >> together.
> > I wanted to suggest
> > but unfortunately it is yet TBD. So I hope that some capable list members
> > can offer some material.
> > Best
> > Markus
> Hi,
> You can look at the ZOO-api.js file.
> If you use the svn trunk you don't have to copy the content of
> ZOO-api.js and ZOO-proj4js.js in your JavaScript Service file else copy
> the content in the head of your file.
> In the API you have classes :
> ZOO.Bounds
> ZOO.Projection
> ZOO.Format
> ZOO.Format.WKT
> ZOO.Format.JSON
> ZOO.Format.GeoJSON
> ZOO.Format.KML
> ZOO.Format.GML
> ZOO.Feature
> ZOO.Geometry
> ZOO.Geometry.Point
> ZOO.Geometry.Surface
> ZOO.Geometry.MultiPoint
> ZOO.Geometry.Curve
> ZOO.Geometry.LineString
> ZOO.Geometry.LinearRing
> ZOO.Geometry.MultiLineString
> ZOO.Geometry.MultiPolygon
> ZOO.Process
> ZOO.Process is a way to query a WPS' process. you can use it like that :
> //ZOO.Process is initialize with an url and a process identifier
> var p = new ZOO.Process('http://localhost/cgi/zoo','hello');
> // inputs in Execute is an object where attributes name are inputs name
> // if input is literal corresponding attribute is the value
> // if input is complex or reference attribute is an object with type and
> value attribute
> // the other attribute represent complement information about the data
> var r = p.Execute({test:'hello'});
> // the result is the XML response of WPS Execute
> Cheers
> René-Luc D'Hont
> JavaScript ZOO API editor
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20101110/d83323bf/attachment.html>
More information about the Zoo-discuss mailing list
