[ZOO-Discuss] Is any documentation or examples regarding how to use ZOO API
Venkatesh Raghavan raghavan at media.osaka-cu.ac.jp
Wed Nov 10 17:37:42 PST 2010
Hi All,
Some very brief examples have been posted at
http://zoo-project.org/trac/wiki/ZooWebSite/ZOOAPI/Examples
Also, the Drift-X implementation by Nick and others effectively
implements service chaining using the ZOO-API. The Drift-X paper
presented at FOSS4G2010 is available at
http://2010.foss4g.org/papers/3631.pdf
Perhaps a more detailed description will be available if/when the
Drift-X paper is published in journal.
Tang, BTW, there is a likelyhood of organizing a ZOO Workshop in
Beijing sometimes between 19-23 Nov 2010. So, if you are based
in Beijing, maybe we have a chance to meet.
Best
Venka
rldhont wrote:
> Le 10/11/2010 09:49, Markus Neteler a écrit :
>> On Wed, Nov 10, 2010 at 1:15 AM, Yingqi Tang<anakintang at gmail.com>  wrote:
>>> Hi all,
>>> I am just wondering if there is any documentation or examples regarding how
>>> to use Zoo API? The FOSS4G pdf tutorial actually has a lot of good
>>> information and helps me successfully set up a running instance of Zoo
>>> kernel, there is very few information about using Zoo API to chain WPS
>>> together.
>> I wanted to suggest
>> but unfortunately it is yet TBD. So I hope that some capable list members
>> can offer some material.
>> Best
>> Markus
> Hi,
> You can look at the ZOO-api.js file.
> If you use the svn trunk you don't have to copy the content of
> ZOO-api.js and ZOO-proj4js.js in your JavaScript Service file else copy
> the content in the head of your file.
> In the API you have classes :
> ZOO.Bounds
> ZOO.Projection
> ZOO.Format
> ZOO.Format.WKT
> ZOO.Format.JSON
> ZOO.Format.GeoJSON
> ZOO.Format.KML
> ZOO.Format.GML
> ZOO.Feature
> ZOO.Geometry
> ZOO.Geometry.Point
> ZOO.Geometry.Surface
> ZOO.Geometry.MultiPoint
> ZOO.Geometry.Curve
> ZOO.Geometry.LineString
> ZOO.Geometry.LinearRing
> ZOO.Geometry.MultiLineString
> ZOO.Geometry.MultiPolygon
> ZOO.Process
> ZOO.Process is a way to query a WPS' process. you can use it like that :
> //ZOO.Process is initialize with an url and a process identifier
> var p = new ZOO.Process('http://localhost/cgi/zoo','hello');
> // inputs in Execute is an object where attributes name are inputs name
> // if input is literal corresponding attribute is the value
> // if input is complex or reference attribute is an object with type and
> value attribute
> // the other attribute represent complement information about the data
> var r = p.Execute({test:'hello'});
> // the result is the XML response of WPS Execute
> Cheers
> René-Luc D'Hont
> JavaScript ZOO API editor
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
