[ZOO-Discuss] Is any documentation or examples regarding how to use ZOO API
Yingqi Tang anakintang at gmail.com
Fri Nov 12 14:07:01 PST 2010
Venka,
Thanks a lot for the information. Unfortunately, I'm not based in Beijing.
I'm in California, U.S.
Thanks
On Wed, Nov 10, 2010 at 5:37 PM, Venkatesh Raghavan <
raghavan at media.osaka-cu.ac.jp> wrote:
> Hi All,
> Some very brief examples have been posted at
> http://zoo-project.org/trac/wiki/ZooWebSite/ZOOAPI/Examples
> Also, the Drift-X implementation by Nick and others effectively
> implements service chaining using the ZOO-API. The Drift-X paper
> presented at FOSS4G2010 is available at
> http://2010.foss4g.org/papers/3631.pdf
> Perhaps a more detailed description will be available if/when the
> Drift-X paper is published in journal.
> Tang, BTW, there is a likelyhood of organizing a ZOO Workshop in
> Beijing sometimes between 19-23 Nov 2010. So, if you are based
> in Beijing, maybe we have a chance to meet.
> Best
> Venka
> rldhont wrote:
> > Le 10/11/2010 09:49, Markus Neteler a écrit :
> >> On Wed, Nov 10, 2010 at 1:15 AM, Yingqi Tang<anakintang at gmail.com>
>  wrote:
> >>> Hi all,
> >>> I am just wondering if there is any documentation or examples regarding
> how
> >>> to use Zoo API? The FOSS4G pdf tutorial actually has a lot of good
> >>> information and helps me successfully set up a running instance of Zoo
> >>> kernel, there is very few information about using Zoo API to chain WPS
> >>> together.
> >> I wanted to suggest
> >> but unfortunately it is yet TBD. So I hope that some capable list
> members
> >> can offer some material.
> >> Best
> >> Markus
> > Hi,
> > You can look at the ZOO-api.js file.
> > If you use the svn trunk you don't have to copy the content of
> > ZOO-api.js and ZOO-proj4js.js in your JavaScript Service file else copy
> > the content in the head of your file.
> > In the API you have classes :
> > ZOO.Bounds
> > ZOO.Projection
> > ZOO.Format
> > ZOO.Format.WKT
> > ZOO.Format.JSON
> > ZOO.Format.GeoJSON
> > ZOO.Format.KML
> > ZOO.Format.GML
> > ZOO.Feature
> > ZOO.Geometry
> > ZOO.Geometry.Point
> > ZOO.Geometry.Surface
> > ZOO.Geometry.MultiPoint
> > ZOO.Geometry.Curve
> > ZOO.Geometry.LineString
> > ZOO.Geometry.LinearRing
> > ZOO.Geometry.MultiLineString
> > ZOO.Geometry.MultiPolygon
> > ZOO.Process
> > ZOO.Process is a way to query a WPS' process. you can use it like that :
> > //ZOO.Process is initialize with an url and a process identifier
> > var p = new ZOO.Process('http://localhost/cgi/zoo','hello');
> > // inputs in Execute is an object where attributes name are inputs name
> > // if input is literal corresponding attribute is the value
> > // if input is complex or reference attribute is an object with type and
> > value attribute
> > // the other attribute represent complement information about the data
> > var r = p.Execute({test:'hello'});
> > // the result is the XML response of WPS Execute
> > Cheers
> > René-Luc D'Hont
> > JavaScript ZOO API editor
> > Zoo-discuss mailing list
> > Zoo-discuss at gisws.media.osaka-cu.ac.jp
> > http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20101112/c4eea395/attachment.html>
More information about the Zoo-discuss mailing list
