[Zoo-discuss] [ZOO-Discuss] Exception when executing request samples
Gérald Fenoy gerald.fenoy at geolabs.fr
Mon Aug 6 01:07:21 PDT 2012
Dear Frakas,
I would like to ask you to subscribe to the new mailing hosted by OSGeo [1] to continue this discussion.
For the issue you're facing about using the test script it is a bit difficult to answer without asking more informations.
First one should be : what is the server you are using to run the test script ? Then what is the request(s) which failed.
Hope to hear back from you on the zoo-discuss at list.osgeo.org,
Best regards,
Gérald Fenoy
[1] http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Le 5 août 2012 à 19:41, Farkas H a écrit :
> Hi list,
> I am newbie to zoo-wps and would appreciate your help.
> When I run the execute request samples from http://www.zoo-project.org/trac/wiki/ZOOWPSImplementationReport I got the following exception:
> "Unenderstood <request> value. Please check that it was set to GetCapabilities, DescribeProcess or Execute."
> Thanks for any advice.
> Cheers,
> Farkas
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo.cgi/zoo-discuss
More information about the Zoo-discuss mailing list
