[Zoo-discuss] [ZOO-Discuss] Exception when executing request samples
Farkas H farkas.dus at gmail.com
Mon Aug 6 12:03:09 PDT 2012
Hi Gérald,
thank you for your quick response.
I followed the zoo-tutorial and copied the five execute requests provided
here [1]
"Synchronous call using asReference", ..., "RawDataOutput test"
and pasted the requests in this html-form [2].
Since the wfs-server "http://dreal-official.geolabs.fr" seems to be down, I
have also tried this wfs-reference [3].
Hope to hear back from you.
Cheers,
Farkas
[1]
http://www.zoo-project.org/trac/wiki/ZOOWPSImplementationReport
[2]
http://zoo-project.org/test_services.html
[3]
http://demo.opengeo.org/geoserver/ows?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&typename=topp:states&SRS=EPSG:4326&FeatureID=states.45
On 6 August 2012 10:07, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> Dear Frakas,
> I would like to ask you to subscribe to the new mailing hosted by OSGeo
> [1] to continue this discussion.
> For the issue you're facing about using the test script it is a bit
> difficult to answer without asking more informations.
> First one should be : what is the server you are using to run the test
> script ? Then what is the request(s) which failed.
> Hope to hear back from you on the zoo-discuss at list.osgeo.org,
> Best regards,
> Gérald Fenoy
> [1] http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Le 5 août 2012 à 19:41, Farkas H a écrit :
> > Hi list,
> > I am newbie to zoo-wps and would appreciate your help.
> > When I run the execute request samples from
> http://www.zoo-project.org/trac/wiki/ZOOWPSImplementationReport I got the
> following exception:
> > "Unenderstood <request> value. Please check that it was set to
> GetCapabilities, DescribeProcess or Execute."
> > Thanks for any advice.
> > Cheers,
> > Farkas
> > Zoo-discuss mailing list
> > Zoo-discuss at gisws.media.osaka-cu.ac.jp
> > http://gisws.media.osaka-cu.ac.jp/mailman/listinfo.cgi/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20120806/2050fc71/attachment.html>
More information about the Zoo-discuss mailing list
