[Zoo-discuss] [ZOO-Discuss] Problem with execute commands on local zooWPS setup
Gérald Fenoy gerald.fenoy at geolabs.fr
Mon Aug 6 01:16:02 PDT 2012
Dear Frakas,
it is interesting to hear that you're using the ZOO-Project on Windows platform.
One more time, I would like to invite you to subscribe to the new mailing list, hosted by OSGeo, to continue this discussion [1].
Nevertheless, to try to answer your question I would like to ask you if you may run the following command :
 depends /library our_sp.zo
This should show you if all the dependents dlls are located in the same  directory.
Hope this help and to hear from you on the zoo-discuss at list.osgeo.org mailing list,
Best regards,
Gérald Fenoy
[1] http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Le 5 août 2012 à 19:52, Farkas H a écrit :
> Hi list,
> Testing my zooWPS setup on Windows 7 with execute commands I got errors (GetCapabilities and DescribeProcess commands are working), eg
> http://localhost/cgi-bin/zoo_loader.cgi/?serviceprovider=&metapath=&request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
> Internal Server Error
> Apache server log:
> Premature end of script headers: zoo_loader.cgi
> MAP => [Centroid] \r
> [mimeType] => [text/js] \r
> [encoding] => [UTF-8] \r
> [value] => [NULL] \r
> The same execute command works on the zoo server:
> http://zoo-project.org/zoosoo?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
> Response result:
> <?xml version="1.0" encoding="utf-8"?>
> <wps:ExecuteResponse xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsExecute_response.xsd" service="WPS" version="1.0.0" xml:lang="en" serviceInstance="http://www.zoo-project.org/zoo/">
>   <wps:Process wps:processVersion="2">
>     <ows:Identifier>Centroid</ows:Identifier>
>     <ows:Title>Get the centroid of a polygon. </ows:Title>
>     <ows:Abstract>Create a buffer around a single polygon. Accepts the polygon as GML and provides GML output for the buffered feature. </ows:Abstract>
>   </wps:Process>
>   <wps:Status creationTime="2012-08-05T07:11:33Z">
>     <wps:ProcessSucceeded/>
>   </wps:Status>
>   <wps:ProcessOutputs>
>     <wps:Output>
>       <ows:Identifier>Result</ows:Identifier>
>       <ows:Title>The Centroid</ows:Title>
>       <wps:Data>
>         <wps:ComplexData mimeType="text/plain" encoding="UTF-8"><![CDATA[<gml:Point><gml:coordinates>-114.585898485152327,44.767769456707043</gml:coordinates></gml:Point>]]></wps:ComplexData>
>       </wps:Data>
>     </wps:Output>
>   </wps:ProcessOutputs>
> </wps:ExecuteResponse>
> What could be the problem? I appreciate any advice.
> Cheers, Farkas
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo.cgi/zoo-discuss
More information about the Zoo-discuss mailing list
