[Zoo-discuss] [ZOO-Discuss] Problem with execute commands on local zooWPS setup
Farkas H farkas.dus at gmail.com
Mon Aug 6 12:30:28 PDT 2012
Hi Gérald,
thank you for your quick response.
So far I just followed the tutorial from "Using OSGeo4W" to "Testing - Now
you should be able ... ZOO Kernel" provided here [1].
I didn't compile my own libraries. I want to do this in the next step.
Since the file depends.exe was not on my machine I got it from here [2].
The provided command "depends /library our_sp.zo" didn't work however.
I appreciate further help.
Cheers,
Farkas
[1]
http://zoo-project.org/docs/kernel/install-windows.html
[2]
http://www.dependencywalker.com/
On 6 August 2012 10:16, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> Dear Frakas,
> it is interesting to hear that you're using the ZOO-Project on Windows
> platform.
> One more time, I would like to invite you to subscribe to the new mailing
> list, hosted by OSGeo, to continue this discussion [1].
> Nevertheless, to try to answer your question I would like to ask you if
> you may run the following command :
> This should show you if all the dependents dlls are located in the same
>  directory.
> Hope this help and to hear from you on the zoo-discuss at list.osgeo.orgmailing list,
> Best regards,
> Gérald Fenoy
> [1] http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Le 5 août 2012 à 19:52, Farkas H a écrit :
> > Hi list,
> > Testing my zooWPS setup on Windows 7 with execute commands I got errors
> (GetCapabilities and DescribeProcess commands are working), eg
> http://localhost/cgi-bin/zoo_loader.cgi/?serviceprovider=&metapath=&request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
> > Internal Server Error
> > Apache server log:
> > Premature end of script headers: zoo_loader.cgi
> > MAP => [Centroid] \r
> > [mimeType] => [text/js] \r
> > [encoding] => [UTF-8] \r
> > [value] => [NULL] \r
> > The same execute command works on the zoo server:
> http://zoo-project.org/zoosoo?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
> > Response result:
> > <?xml version="1.0" encoding="utf-8"?>
> > <wps:ExecuteResponse xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:xlink="
> http://www.w3.org/1999/xlink" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/wps/1.0.0/wpsExecute_response.xsd"
> service="WPS" version="1.0.0" xml:lang="en" serviceInstance="
> http://www.zoo-project.org/zoo/">
> >   <wps:Process wps:processVersion="2">
> >     <ows:Identifier>Centroid</ows:Identifier>
> >     <ows:Title>Get the centroid of a polygon. </ows:Title>
> >     <ows:Abstract>Create a buffer around a single polygon. Accepts the
> polygon as GML and provides GML output for the buffered feature.
> </ows:Abstract>
> >   </wps:Process>
> >   <wps:Status creationTime="2012-08-05T07:11:33Z">
> >     <wps:ProcessSucceeded/>
> >   </wps:Status>
> >   <wps:ProcessOutputs>
> >     <wps:Output>
> >       <ows:Identifier>Result</ows:Identifier>
> >       <ows:Title>The Centroid</ows:Title>
> >       <wps:Data>
> >         <wps:ComplexData mimeType="text/plain"
> encoding="UTF-8"><![CDATA[<gml:Point><gml:coordinates>-114.585898485152327,44.767769456707043</gml:coordinates></gml:Point>]]></wps:ComplexData>
> >       </wps:Data>
> >     </wps:Output>
> >   </wps:ProcessOutputs>
> > </wps:ExecuteResponse>
> > What could be the problem? I appreciate any advice.
> > Cheers, Farkas
> > Zoo-discuss mailing list
> > Zoo-discuss at gisws.media.osaka-cu.ac.jp
> > http://gisws.media.osaka-cu.ac.jp/mailman/listinfo.cgi/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20120806/a6901f96/attachment.html>
More information about the Zoo-discuss mailing list
