[Zoo-discuss] [ZOO-Discuss] Problem with execute commands on local zooWPS setup
Gérald Fenoy gerald.fenoy at geolabs.fr
Wed Aug 8 00:54:36 PDT 2012
Hello Farkas,
nice to hear back from you. Sorry for my mistake in providing the
command to check dependencies which was wrong.
This is is the correct command to use to check dependencies with
standard tools providen in Visual Studio Express edition:
dumpbin /dependents ogr_sp.zo
Note that it may be interesting also to try running the same request
from the command prompt to see more clearly what is happening when
Apache is trying to run the program. To run ZOO-Kernel from the command
line, please use the following syntaxe :
.\zoo_loader.cgi "<YOUR_REQUEST>"
Where <YOUR_REQUEST> should be replaced by the content following the
quotation mark in the url you providen.
I hope that this will help us to understand better where the issue
occurs.
Hope to hear back from you,
Best regards,
Le lundi 06 août 2012 à 21:30 +0200, Farkas H a écrit :
> Hi Gérald,
> thank you for your quick response.
> So far I just followed the tutorial from "Using OSGeo4W" to "Testing -
> Now you should be able ... ZOO Kernel" provided here [1].
> I didn't compile my own libraries. I want to do this in the next step.
> Since the file depends.exe was not on my machine I got it from here
> [2].
> The provided command "depends /library our_sp.zo" didn't work however.
> I appreciate further help.
> Cheers,
> Farkas
> [1]
> http://zoo-project.org/docs/kernel/install-windows.html
> [2]
> http://www.dependencywalker.com/
> On 6 August 2012 10:16, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
>         Dear Frakas,
>         it is interesting to hear that you're using the ZOO-Project on
>         Windows platform.
>         One more time, I would like to invite you to subscribe to the
>         new mailing list, hosted by OSGeo, to continue this discussion
>         [1].
>         Nevertheless, to try to answer your question I would like to
>         ask you if you may run the following command :
>         This should show you if all the dependents dlls are located in
>         the same  directory.
>         Hope this help and to hear from you on the
>         zoo-discuss at list.osgeo.org mailing list,
>         Best regards,
>         Gérald Fenoy
>         [1]
>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
>         Le 5 août 2012 à 19:52, Farkas H a écrit :
>         > Hi list,
>         > Testing my zooWPS setup on Windows 7 with execute commands I
>         got errors (GetCapabilities and DescribeProcess commands are
>         working), eg
>         http://localhost/cgi-bin/zoo_loader.cgi/?serviceprovider=&metapath=&request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
>         > Internal Server Error
>         > Apache server log:
>         > Premature end of script headers: zoo_loader.cgi
>         > MAP => [Centroid] \r
>         > [mimeType] => [text/js] \r
>         > [encoding] => [UTF-8] \r
>         > [value] => [NULL] \r
>         > The same execute command works on the zoo server:
>         http://zoo-project.org/zoosoo?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
>         > Response result:
>         > <?xml version="1.0" encoding="utf-8"?>
>         > <wps:ExecuteResponse
>         xmlns:ows="http://www.opengis.net/ows/1.1"
>         xmlns:wps="http://www.opengis.net/wps/1.0.0"
>         xmlns:xlink="http://www.w3.org/1999/xlink"
>         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>         xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
>         http://schemas.opengis.net/wps/1.0.0/wpsExecute_response.xsd"
>         service="WPS" version="1.0.0" xml:lang="en"
>         serviceInstance="http://www.zoo-project.org/zoo/">
>         >   <wps:Process wps:processVersion="2">
>         >     <ows:Identifier>Centroid</ows:Identifier>
>         >     <ows:Title>Get the centroid of a polygon. </ows:Title>
>         >     <ows:Abstract>Create a buffer around a single polygon.
>         Accepts the polygon as GML and provides GML output for the
>         buffered feature. </ows:Abstract>
>         >   </wps:Process>
>         >   <wps:Status creationTime="2012-08-05T07:11:33Z">
>         >     <wps:ProcessSucceeded/>
>         >   </wps:Status>
>         >   <wps:ProcessOutputs>
>         >     <wps:Output>
>         >       <ows:Identifier>Result</ows:Identifier>
>         >       <ows:Title>The Centroid</ows:Title>
>         >       <wps:Data>
>         >         <wps:ComplexData mimeType="text/plain"
>         encoding="UTF-8"><![CDATA[<gml:Point><gml:coordinates>-114.585898485152327,44.767769456707043</gml:coordinates></gml:Point>]]></wps:ComplexData>
>         >       </wps:Data>
>         >     </wps:Output>
>         >   </wps:ProcessOutputs>
>         > </wps:ExecuteResponse>
>         > What could be the problem? I appreciate any advice.
>         > Cheers, Farkas
>         > _______________________________________________
>         > Zoo-discuss mailing list
>         > Zoo-discuss at gisws.media.osaka-cu.ac.jp
>         http://gisws.media.osaka-cu.ac.jp/mailman/listinfo.cgi/zoo-discuss
> Zoo-discuss at lists.osgeo.org
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20120808/8379ea4a/attachment.pgp>
More information about the Zoo-discuss mailing list
