[Zoo-discuss] [ZOO-Discuss] Problem with execute commands on local zooWPS setup
Farkas H farkas.dus at gmail.com
Wed Aug 8 09:17:45 PDT 2012
Hi Gérald,
thank you for your response.
I'm becoming a little bit confused.
There is no file ogr_sp.zo. I have got the files ogr_service.zo and
ogr2ogr_service.zo.
You can find the dependencies check for 'ogr_service.zo' here [3].
You can find the dependencies check for 'ogr2ogr_service.zo' here [4].
You can find the dependencies check for 'zoo_loader.cgi' here [5].
As mentioned before I used the installer from http://trac.osgeo.org/osgeo4w/.
I didn't compile the kernel.
Maybe that's the reason!?
I tried to compile the kernel and got the error "Cannot open include file:
'fcgio.h' ..."
Hope to hear from you again.
Cheers,
Farkas
[3]
Dump of file C:\OSGeo4W\bin\ogr_service.zo
File Type: DLL
LINK : warning LNK4078: multiple '.text' sections found with different
attribute
s (E0000020)
  Image has the following dependencies:
    libxml2.dll
    gdal15.dll
    KERNEL32.dll
  Summary
        3000 .data
        4000 .rdata
        2000 .reloc
        1000 .text
        F000 .text
[4]
Dump of file C:\OSGeo4W\bin\ogr2ogr_service.zo
File Type: DLL
attribute
s (E0000020)
    gdal15.dll
    KERNEL32.dll
  Summary
        4000 .data
       10000 .rdata
        3000 .reloc
        1000 .text
       19000 .text
[5]
Dump of file C:\OSGeo4W\bin\zoo_loader.cgi
File Type: EXECUTABLE IMAGE
attribute
s (E0000020)
    libfcgi.dll
    libcurl.dll
    python25.dll
    libxml2.dll
    KERNEL32.dll
  Summary
       24000 .data
        9000 .rdata
        1000 .text
       23000 .text
On 8 August 2012 09:54, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> Hello Farkas,
> nice to hear back from you. Sorry for my mistake in providing the
> command to check dependencies which was wrong.
> This is is the correct command to use to check dependencies with
> standard tools providen in Visual Studio Express edition:
> dumpbin /dependents ogr_sp.zo
> Note that it may be interesting also to try running the same request
> from the command prompt to see more clearly what is happening when
> Apache is trying to run the program. To run ZOO-Kernel from the command
> line, please use the following syntaxe :
> .\zoo_loader.cgi "<YOUR_REQUEST>"
> Where <YOUR_REQUEST> should be replaced by the content following the
> quotation mark in the url you providen.
> I hope that this will help us to understand better where the issue
> occurs.
> Hope to hear back from you,
> Best regards,
> Le lundi 06 août 2012 à 21:30 +0200, Farkas H a écrit :
> > Hi Gérald,
> > thank you for your quick response.
> > So far I just followed the tutorial from "Using OSGeo4W" to "Testing -
> > Now you should be able ... ZOO Kernel" provided here [1].
> > I didn't compile my own libraries. I want to do this in the next step.
> > Since the file depends.exe was not on my machine I got it from here
> > [2].
> > The provided command "depends /library our_sp.zo" didn't work however.
> > I appreciate further help.
> > Cheers,
> > Farkas
> > [1]
> > http://zoo-project.org/docs/kernel/install-windows.html
> > [2]
> > http://www.dependencywalker.com/
> > On 6 August 2012 10:16, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> >         Dear Frakas,
> >         it is interesting to hear that you're using the ZOO-Project on
> >         Windows platform.
> >         One more time, I would like to invite you to subscribe to the
> >         new mailing list, hosted by OSGeo, to continue this discussion
> >         [1].
> >         Nevertheless, to try to answer your question I would like to
> >         ask you if you may run the following command :
> >         This should show you if all the dependents dlls are located in
> >         the same  directory.
> >         Hope this help and to hear from you on the
> >         zoo-discuss at list.osgeo.org mailing list,
> >         Best regards,
> >         Gérald Fenoy
> >         [1]
> >         http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> >         Le 5 août 2012 à 19:52, Farkas H a écrit :
> >         > Hi list,
> >         > Testing my zooWPS setup on Windows 7 with execute commands I
> >         got errors (GetCapabilities and DescribeProcess commands are
> >         working), eg
> http://localhost/cgi-bin/zoo_loader.cgi/?serviceprovider=&metapath=&request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
> >         > Internal Server Error
> >         > Apache server log:
> >         > Premature end of script headers: zoo_loader.cgi
> >         > MAP => [Centroid] \r
> >         > [mimeType] => [text/js] \r
> >         > [encoding] => [UTF-8] \r
> >         > [value] => [NULL] \r
> >         > The same execute command works on the zoo server:
> http://zoo-project.org/zoosoo?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
> >         > Response result:
> >         > <?xml version="1.0" encoding="utf-8"?>
> >         > <wps:ExecuteResponse
> >         xmlns:ows="http://www.opengis.net/ows/1.1"
> >         xmlns:wps="http://www.opengis.net/wps/1.0.0"
> >         xmlns:xlink="http://www.w3.org/1999/xlink"
> >         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> >         xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
> >         http://schemas.opengis.net/wps/1.0.0/wpsExecute_response.xsd"
> >         service="WPS" version="1.0.0" xml:lang="en"
> >         serviceInstance="http://www.zoo-project.org/zoo/">
> >         >   <wps:Process wps:processVersion="2">
> >         >     <ows:Identifier>Centroid</ows:Identifier>
> >         >     <ows:Title>Get the centroid of a polygon. </ows:Title>
> >         >     <ows:Abstract>Create a buffer around a single polygon.
> >         Accepts the polygon as GML and provides GML output for the
> >         buffered feature. </ows:Abstract>
> >         >   </wps:Process>
> >         >   <wps:Status creationTime="2012-08-05T07:11:33Z">
> >         >     <wps:ProcessSucceeded/>
> >         >   </wps:Status>
> >         >   <wps:ProcessOutputs>
> >         >     <wps:Output>
> >         >       <ows:Identifier>Result</ows:Identifier>
> >         >       <ows:Title>The Centroid</ows:Title>
> >         >       <wps:Data>
> >         >         <wps:ComplexData mimeType="text/plain"
> encoding="UTF-8"><![CDATA[<gml:Point><gml:coordinates>-114.585898485152327,44.767769456707043</gml:coordinates></gml:Point>]]></wps:ComplexData>
> >         >       </wps:Data>
> >         >     </wps:Output>
> >         >   </wps:ProcessOutputs>
> >         > </wps:ExecuteResponse>
> >         > What could be the problem? I appreciate any advice.
> >         > Cheers, Farkas
> >         > _______________________________________________
> >         > Zoo-discuss mailing list
> >         > Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo.cgi/zoo-discuss
> > Zoo-discuss at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20120808/ceb7ca9b/attachment-0001.html>
More information about the Zoo-discuss mailing list
