[Zoo-discuss] [ZOO-PSC] ZOO-Project 1.4.0 was released today
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Tue Dec 9 06:53:46 PST 2014
Is there a MapMint/ZOO workshop available somewhere?
Bye
steve
Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp>@lists.osgeo.org
Envoyé par : zoo-discuss-bounces at lists.osgeo.org
2014-12-09 09:09
A
ZOO-discuss <zoo-discuss at lists.osgeo.org>, zoo-psc
<zoo-psc at lists.osgeo.org>
cc
Objet
Re: [Zoo-discuss] [ZOO-PSC] ZOO-Project 1.4.0 was released today
Hi Gerald,
Thanks for the excellent enhancements in the new release of ZOO-1.4.0.
Just completed a MapMint/ZOO workshop during GIS-IDEAS 2014 in
Danang, Vietnam with 30 participants. The workshop went off smoothly,
but wish I could have done it with the new version of ZOO!!
Best,
Venka
On 2014/12/09 16:31, Fenoy Gerald wrote:
> Dear ZOO-Project users,
> the ZOO-Project developper team is pleased to announce the ZOO-Project
1.4.0 release [1].
> This release should work correctly on both GNU/Linux, MacOS X and WIN32
platforms.
> You can download the archives from [2] (zip) and [3]  (tar.bz2) or use
Subversion:
>    svn co http://svn.zoo-project.org/svn/tags/rel-1.4.0/
zoo-project-1.4.0
> The most important modifications / fixes are listed below:
>   * Small fix for mimeType of results for CGAL services
>   * Binary support for PHP language
>   * ZOO-API for the Java language
>   * ZOO-Client Javascript API
>   * FastCGI fixes
>   * JavaScript ZOO-API enhancements (COOKIE use and Output in generated
XML)
>   * Add debian files
>   * Inputs passed by reference downloaded in parallel
>   * Conform behavior for DescribeProcess when the Identifier was not
found
>   * Add support of maximumMegabytes keywords for ComplexData Inputs
>   * Add the optional YAML ZCFG support #4 and the zcfg2yaml converter
>   * Return error messages that enable the service provider to quickly
identify the root cause of errors due to configuration file syntax (ticket
#90)
>   * Fix logic in addMapToMap (ticket #91)
>   * Enable AllowedValue and multiple Range definitions using default and
supported blocks
>   * Add the lastest revision number in version.h (available in Python
ZOO-API)
>   * Add the optional Ruby Language Support to the ZOO-Kernel with an API
similar to the Python ZOO-API
>   * Small rewrite of Python support
>   * Inputs can be requested over https protocol (ticket #86)
>   * Add capability to define both percentage of execution and a message
(ticket #87).
>   * Add usid in lenv section used to generate an unique identifier based
on time and the process identifier.
>   * Add gdal_contour service
>   * Add dynamic definition of serverAddress from the main section
> This work was supported by a grant from the European Union's 7th
Framework Programme (2007-2013) provided for the project PublicaMundi (GA
no. 609608).
> I hope you can have good time using this new ZOO-Project release,
> Best regards,
> Gérald Fenoy
> ZOO-PSC Chair
> [1] http://www.zoo-project.org/site/Downloads#ZOO-Projectversion1.4.0
> [2] http://zoo-project.org/dl/zoo-project-1.4.0.zip
> [3] http://zoo-project.org/dl/zoo-project-1.4.0.tar.bz2
> Zoo-psc mailing list
> Zoo-psc at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-psc
Zoo-discuss mailing list
Zoo-discuss at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20141209/65c2fd1e/attachment.html>
More information about the Zoo-discuss mailing list
