[Zoo-discuss] [ZOO-PSC] ZOO-Project 1.4.0 was released today
Venkatesh Raghavan raghavan at media.osaka-cu.ac.jp
Tue Dec 9 07:53:45 PST 2014
On 2014/12/09 23:53, Steve.Toutant at inspq.qc.ca wrote:
> Is there a MapMint/ZOO workshop available somewhere?
ZOO workshop material is available at
http://www.zoo-project.org/docs/
We will try to put up the MapMint WS material on internet in
the future.
Best
Venka
> Bye
> steve
> Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp>@lists.osgeo.org
> Envoyé par : zoo-discuss-bounces at lists.osgeo.org
> 2014-12-09 09:09
> A
> ZOO-discuss <zoo-discuss at lists.osgeo.org>, zoo-psc
> <zoo-psc at lists.osgeo.org>
> cc
> Objet
> Re: [Zoo-discuss] [ZOO-PSC] ZOO-Project 1.4.0 was released today
> Hi Gerald,
> Thanks for the excellent enhancements in the new release of ZOO-1.4.0.
> Just completed a MapMint/ZOO workshop during GIS-IDEAS 2014 in
> Danang, Vietnam with 30 participants. The workshop went off smoothly,
> but wish I could have done it with the new version of ZOO!!
> Best,
> Venka
> On 2014/12/09 16:31, Fenoy Gerald wrote:
>> Dear ZOO-Project users,
>> the ZOO-Project developper team is pleased to announce the ZOO-Project
> 1.4.0 release [1].
>> This release should work correctly on both GNU/Linux, MacOS X and WIN32
> platforms.
>> You can download the archives from [2] (zip) and [3]  (tar.bz2) or use
> Subversion:
>>     svn co http://svn.zoo-project.org/svn/tags/rel-1.4.0/
> zoo-project-1.4.0
>> The most important modifications / fixes are listed below:
>>    * Small fix for mimeType of results for CGAL services
>>    * Binary support for PHP language
>>    * ZOO-API for the Java language
>>    * ZOO-Client Javascript API
>>    * FastCGI fixes
>>    * JavaScript ZOO-API enhancements (COOKIE use and Output in generated
> XML)
>>    * Add debian files
>>    * Inputs passed by reference downloaded in parallel
>>    * Conform behavior for DescribeProcess when the Identifier was not
> found
>>    * Add support of maximumMegabytes keywords for ComplexData Inputs
>>    * Add the optional YAML ZCFG support #4 and the zcfg2yaml converter
>>    * Return error messages that enable the service provider to quickly
> identify the root cause of errors due to configuration file syntax (ticket
> #90)
>>    * Fix logic in addMapToMap (ticket #91)
>>    * Enable AllowedValue and multiple Range definitions using default and
> supported blocks
>>    * Add the lastest revision number in version.h (available in Python
> ZOO-API)
>>    * Add the optional Ruby Language Support to the ZOO-Kernel with an API
> similar to the Python ZOO-API
>>    * Small rewrite of Python support
>>    * Inputs can be requested over https protocol (ticket #86)
>>    * Add capability to define both percentage of execution and a message
> (ticket #87).
>>    * Add usid in lenv section used to generate an unique identifier based
> on time and the process identifier.
>>    * Add gdal_contour service
>>    * Add dynamic definition of serverAddress from the main section
>> This work was supported by a grant from the European Union's 7th
> Framework Programme (2007-2013) provided for the project PublicaMundi (GA
> no. 609608).
>> I hope you can have good time using this new ZOO-Project release,
>> Best regards,
>> Gérald Fenoy
>> ZOO-PSC Chair
>> [1] http://www.zoo-project.org/site/Downloads#ZOO-Projectversion1.4.0
>> [2] http://zoo-project.org/dl/zoo-project-1.4.0.zip
>> [3] http://zoo-project.org/dl/zoo-project-1.4.0.tar.bz2
>> Zoo-psc mailing list
>> Zoo-psc at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-psc
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20141210/61652c40/attachment-0001.html>
More information about the Zoo-discuss mailing list
