[Zoo-discuss] Non exist version.h (zoo-service)
Fenoy Gerald gerald.fenoy at geolabs.fr
Sun Jun 22 10:51:12 PDT 2014
Hi Pablo,
referring to this ticket #99 ([1]), it seems your are not the first one to face this kind of issue.
The version.h file is not present in the SVN trunk as it should be produced once running make. Obviously, this imply that you have an up-to-date ZOO-Kernel from trunk to have this file generated.
I hope this help you to solve this issue if you did not already solved it.
Waiting for your answer,
Best regards,
[1] http://zoo-project.org/trac/ticket/99
Le 21 juin 2014 à 22:19, pablo zader <pzader at gmail.com> a écrit :
> Hi List,
> I want to incorporate service GetStatus to take the state of the execution of long processes but I have problems compiling this:
> ~/zoo-project/zoo-project/zoo-services/utils/status$ make
> g++ -I../../../../thirds/cgic206/ -I../../../zoo-kernel/ -I/usr/include/libxml2 -I/usr/local/include -I/usr/include/python2.7 -I/usr/include/python2.7 -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -DLINUX_FREE_ISSUE  -shared -fpic -o cgi-env/wps_status.zo ./service.c ../../../zoo-kernel/service_internal.o ../../../zoo-kernel/  ../../../zoo-kernel/ulinet.o ../../../zoo-kernel/service_internal_js.o -lcurl  -L/usr/lib -lmozjs185 -lm -L/usr/local/lib -lgdal -L/usr/lib -lxml2  -lcrypto  `xslt-config --libs` -lfcgi
> cc1plus: aviso: la opción de línea de órdenes ‘-Wstrict-prototypes’ es válida para Ada/C/ObjC pero no para C++ [activado por defecto]
> In file included from ./service.c:25:0:
> ../../../zoo-kernel/service.h:84:22: error fatal: version.h: No existe el archivo o el directorio
> compilación terminada.
> make: *** [cgi-env/wps_status.zo] Error 1
> The file version.h actually does not exist in the directory:
> ~/zoo-project/zoo-project/zoo-services/utils/status$ ls ../../../zoo-kernel/
> autom4te.cache  locale                README                   service_internal_js.c    service_internal_python.c  zoo_loader.c
> config.log      main.cfg              service_conf.l           service_internal_js.h    service_internal_python.h  zoo_loader.cgi
> config.status   main_conf_read.l      service_conf.tab.c       service_internal_js.o    service_internal_python.o  zoo_loader.o
> configure       main_conf_read.tab.c  service_conf.tab.h       service_internal_ms.c    service_internal_ruby.c    ZOOMakefile.opts
> configure.ac    main_conf_read.tab.h  service_conf.tab.o       service_internal_ms.h    service_internal_ruby.h    ZOOMakefile.opts.in
> Doxyfile        main_conf_read.tab.o  service_conf.y           service_internal_ms.o    service_loader.c           zoo_service_loader.c
> lex.cr.c        main_conf_read.y      service.h                service_internal.o       service_yaml.c             zoo_service_loader.o
> lex.cr.o        Makefile              service_internal.c       service_internal_perl.c  ulinet.c
> lex.sr.c        Makefile.in           service_internal.h       service_internal_perl.h  ulinet.h
> lex.sr.o        makefile.vc           service_internal_java.c  service_internal_php.c   ulinet.o
> LICENSE         nmake.opt             service_internal_java.h  service_internal_php.h   zcfg2yaml.c
> as I can fix the problem?
> Thanks!
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140622/775fcedf/attachment.pgp>
More information about the Zoo-discuss mailing list
