[Zoo-discuss] Non exist version.h (zoo-service)
pablo zader pzader at gmail.com
Mon Jun 23 11:48:07 PDT 2014
Gèrald and Steve,
I solved it doing (by Steve Tountant) :
echo "#define ZOO_VERSION \"svnversion\"" > version.h
inside of directory :
~/zoo-project/zoo-project/zoo-kernel
The problem was due to the order is not in the Makefile  of Review 488
which currently use. But in the review 487 exist such order! (
http://zoo-project.org/trac/browser/trunk/zoo-project/zoo-kernel/Makefile.in#L31)
I
suppose there is an error in the review 488.
Thanks Gérald and Steve
2014-06-22 14:51 GMT-03:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Hi Pablo,
> referring to this ticket #99 ([1]), it seems your are not the first one to
> face this kind of issue.
> The version.h file is not present in the SVN trunk as it should be
> produced once running make. Obviously, this imply that you have an
> up-to-date ZOO-Kernel from trunk to have this file generated.
> I hope this help you to solve this issue if you did not already solved it.
> Waiting for your answer,
> Best regards,
> [1] http://zoo-project.org/trac/ticket/99
> Le 21 juin 2014 à 22:19, pablo zader <pzader at gmail.com> a écrit :
> > Hi List,
> > I want to incorporate service GetStatus to take the state of the
> execution of long processes but I have problems compiling this:
> > ~/zoo-project/zoo-project/zoo-services/utils/status$ make
> > g++ -I../../../../thirds/cgic206/ -I../../../zoo-kernel/
> -I/usr/include/libxml2 -I/usr/local/include -I/usr/include/python2.7
> -I/usr/include/python2.7 -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall
> -Wstrict-prototypes -g -fstack-protector --param=ssp-buffer-size=4 -Wformat
> -Wformat-security -Werror=format-security -DLINUX_FREE_ISSUE  -shared -fpic
> -o cgi-env/wps_status.zo ./service.c ../../../zoo-kernel/service_internal.o
> ../../../zoo-kernel/  ../../../zoo-kernel/ulinet.o
> ../../../zoo-kernel/service_internal_js.o -lcurl  -L/usr/lib -lmozjs185 -lm
> -L/usr/local/lib -lgdal -L/usr/lib -lxml2  -lcrypto  `xslt-config --libs`
> -lfcgi
> > cc1plus: aviso: la opción de línea de órdenes ‘-Wstrict-prototypes’ es
> válida para Ada/C/ObjC pero no para C++ [activado por defecto]
> > In file included from ./service.c:25:0:
> > ../../../zoo-kernel/service.h:84:22: error fatal: version.h: No existe
> el archivo o el directorio
> > compilación terminada.
> > make: *** [cgi-env/wps_status.zo] Error 1
> > The file version.h actually does not exist in the directory:
> > ~/zoo-project/zoo-project/zoo-services/utils/status$ ls
> > autom4te.cache  locale                README
> service_internal_js.c    service_internal_python.c  zoo_loader.c
> > config.log      main.cfg              service_conf.l
> service_internal_js.h    service_internal_python.h  zoo_loader.cgi
> > config.status   main_conf_read.l      service_conf.tab.c
> service_internal_js.o    service_internal_python.o  zoo_loader.o
> > configure       main_conf_read.tab.c  service_conf.tab.h
> service_internal_ms.c    service_internal_ruby.c    ZOOMakefile.opts
> > configure.ac    main_conf_read.tab.h  service_conf.tab.o
> service_internal_ms.h    service_internal_ruby.h    ZOOMakefile.opts.in
> > Doxyfile        main_conf_read.tab.o  service_conf.y
> service_internal_ms.o    service_loader.c           zoo_service_loader.c
> > lex.cr.c        main_conf_read.y      service.h
>  service_internal.o       service_yaml.c             zoo_service_loader.o
> > lex.cr.o        Makefile              service_internal.c
> service_internal_perl.c  ulinet.c
> > lex.sr.c        Makefile.in           service_internal.h
> service_internal_perl.h  ulinet.h
> > lex.sr.o        makefile.vc           service_internal_java.c
>  service_internal_php.c   ulinet.o
> > LICENSE         nmake.opt             service_internal_java.h
>  service_internal_php.h   zcfg2yaml.c
> > as I can fix the problem?
> > Thanks!
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Gérald Fenoy
*Pablo J. Zader*
*Lic. en Cs. de la Computación*
*CONAE *
*pablo.zader at gmail.com <pablo.zader at gmail.com>*
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahi? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140623/89f498ec/attachment.html>
More information about the Zoo-discuss mailing list
