[Zoo-discuss] r.what is supported?
truongxuan quang truongxuanquang at yahoo.com
Mon Nov 3 02:51:55 PST 2014
I think, it was some problem with GRASS bridge's setup it should completely correct in the setting in GlobalGrassSetting.py file and so on e.g.:
WORKDIR="/tmp"
OUTPUTDIR="/tmp"
LOGFILE="/tmp/logfile.txt"
LOGFILE_MODULE_STDOUT="/tmp/logfile_module_stdout.txt"
LOGFILE_MODULE_STDERR="/tmp/logfile_module_sterr.txt"
GRASS_GIS_BASE="/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu"
GRASS_ADDON_PATH="/home/soeren/src/wps-grass-bridge/gms/Testing/Python/GrassAddons"
GRASS_VERSION="7.0.svn"
it is better if you can show us the apache log file for more detail, apache log file in /var/log/apache2/error.log  |
I hope this helps.
Best regards,
Quang
     On Friday, October 31, 2014 12:24 AM, pablo zader <pzader at gmail.com> wrote:
 Hi guys,
The grass gis command r.what is supported in zoo-proyect? I have the next problem:
http://localhost/cgi-bin/zoo_loader.cgi?request=execute&service=WPS&version=1.0.0&Identifier=r_what&DataInputs=map=Reference@xlink:href=http_to_wcs_local;coordinates=-65.0,-30.0;grass_band_number=1&ResponseDocument=output
<ExceptionReport xmlns="http://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd" xml:lang="en-US" version="1.1.0"><Exception exceptionCode="NoApplicableCode"><ExceptionText>TRACE : GRASS module r.in.gdal not found in /opt/wps-grass-bridge-read-only/trunk/gms/Testing/Python/GrassAddons/r.in.gdal <class 'gms.ErrorHandler.GMSError'> Unable to run your python process properly. Please check the following messages : [' File "/usr/lib/cgi-bin/r_what.py", line 7, in r_what\n service.fromMaps("r.what", inputs, outputs)\n', ' File "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 77, in fromMaps\n self._importData()\n', ' File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 469, in _importData\n self._createInputLocation(input)\n', ' File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 553, in _createInputLocation\n parameter = [self._createGrassModulePath("r.in.gdal"), "input=" + input.pathToFile, "location=" + GRASS_WORK_LOCATION , "-ce", "output=undefined"]\n', ' File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 888, in _createGrassModulePath\n raise GMSError(log)\n']</ExceptionText></Exception></ExceptionReport>
Thanks in advanced
Pablo
Zoo-discuss mailing list
Zoo-discuss at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20141103/6baa1276/attachment.html>
More information about the Zoo-discuss mailing list
