[Zoo-discuss] r.what is supported?
pablo zader pzader at gmail.com
Mon Nov 3 08:48:31 PST 2014
Yes, r.what  is supported in zoo-proyect.
I edited the GlobalGrassSetting.py settings and now it works fine!
Thanks.
2014-11-03 7:51 GMT-03:00 truongxuan quang <truongxuanquang at yahoo.com>:
> I think, it was some problem with GRASS bridge's setup
> it should completely correct in the setting in
> GlobalGrassSetting.py file and so on e.g.:
> WORKDIR="/tmp"
> OUTPUTDIR="/tmp"
> LOGFILE="/tmp/logfile.txt"
> LOGFILE_MODULE_STDOUT="/tmp/logfile_module_stdout.txt"
> LOGFILE_MODULE_STDERR="/tmp/logfile_module_sterr.txt"
> GRASS_GIS_BASE="/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu"
> GRASS_ADDON_PATH="/home/soeren/src/wps-grass-bridge/gms/Testing/Python/GrassAddons"
> GRASS_VERSION="7.0.svn"
> it is better if you can show us the apache log file for more detail,
> apache log file in /var/log/apache2/error.log
> I hope this helps.
> Best regards,
> Quang
>   On Friday, October 31, 2014 12:24 AM, pablo zader <pzader at gmail.com>
> wrote:
> Hi guys,
> The grass gis command r.what is supported in zoo-proyect?
> I have the next problem:
> http://localhost/cgi-bin/zoo_loader.cgi?request=execute&service=WPS&version=1.0.0&Identifier=r_what&DataInputs=map=Reference@xlink:href=http_to_wcs_local;coordinates=-65.0,-30.0;grass_band_number=1&ResponseDocument=output
> <ExceptionReport xmlns="http://www.opengis.net/ows/1.1" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd" xml:lang="
> en-US" version="1.1.0">
> <Exception exceptionCode="NoApplicableCode">
> <ExceptionText>
> TRACE : GRASS module r.in.gdal not found in
> /opt/wps-grass-bridge-read-only/trunk/gms/Testing/Python/GrassAddons/r.in.gdal
> <class 'gms.ErrorHandler.GMSError'> Unable to run your python process
> properly. Please check the following messages : [' File
> "/usr/lib/cgi-bin/r_what.py", line 7, in r_what\n
> service.fromMaps("r.what", inputs, outputs)\n', ' File
> "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 77, in fromMaps\n
> self._importData()\n', ' File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py",
> line 469, in _importData\n self._createInputLocation(input)\n', ' File
> "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 553, in
> _createInputLocation\n parameter =
> [self._createGrassModulePath("r.in.gdal"), "input=" + input.pathToFile,
> "location=" + GRASS_WORK_LOCATION , "-ce", "output=undefined"]\n', ' File
> "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 888, in
> _createGrassModulePath\n raise GMSError(log)\n']
> </ExceptionText>
> </Exception>
> </ExceptionReport>
> Thanks in advanced
> Pablo
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
*Pablo J. Zader*
*Lic. en Cs. de la Computación*
*CONAE *
*pablo.zader at gmail.com <pablo.zader at gmail.com>*
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahi? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20141103/7019a4cd/attachment-0001.html>
More information about the Zoo-discuss mailing list
