[Zoo-discuss] Zoo WPS Tuning
Ebrahim Poorazizi ebrahim.poorazizi at gmail.com
Thu Nov 27 10:59:53 PST 2014
Hi Nick,
Thanks so much for the quick reply. I will definitely share the results with the ZOO community once I finish the tests.
Regards,
Ebrahim Poorazizi
http://ebrahim.planyourplace.ca/
> On Nov 12, 2014, at 3:45 AM, nicolas bozon <nicolas.bozon at gmail.com> wrote:
> Hello Ebrahim,
> Thank you for your interest in ZOO-Project and for sharing this good paper on this list.
> About tuning ZOO-Kernel to get best performances, i would definitely recommend to get the latest ZOO source code from svn and to compile it as fastcgi. You would probably get even better results with nginx.
> Hope it helps.
> Please do not hesitate to share your future results here too !
> Best regards,
> Nick
> 2014-11-12 7:28 GMT+01:00 Ebrahim Poorazizi <ebrahim.poorazizi at gmail.com <mailto:ebrahim.poorazizi at gmail.com>>:
> Hi list,
> I had a presentation at FOSS4G 2014 on the evaluation of WPS frameworks including 52North, Deegree, GeoServer, Zoo, and PyWPS (See the links below). We had a very good discussion at the end of the talk and the guys suggested to tune the servers before the testing. As I am going to compare the performance of the WPS servers on both local and cloud environments using different scenarios, it would be much appreciated if you let me know what configuration would result in the best performance.
> I look forward to hearing from you.
> Slides: https://speakerdeck.com/mepa1363/evaluation-of-web-processing-service-frameworks <https://speakerdeck.com/mepa1363/evaluation-of-web-processing-service-frameworks>
> Video: https://vimeo.com/107481251 <https://vimeo.com/107481251>
> Paper: https://www.academia.edu/8754816/Evaluation_of_Web_Processing_Service_Frameworks <https://www.academia.edu/8754816/Evaluation_of_Web_Processing_Service_Frameworks>
> Regards,
> Ebrahim Poorazizi
> http://ebrahim.planyourplace.ca/ <http://ebrahim.planyourplace.ca/>
>> Begin forwarded message:
>> From: Ebrahim Poorazizi <mepooraz at ucalgary.ca <mailto:mepooraz at ucalgary.ca>>
>> Subject: Zoo WPS Tuning
>> Date: November 5, 2014 at 12:58:09 PM MST
>> To: <gerald.fenoy at geolabs.fr <mailto:gerald.fenoy at geolabs.fr>>
>> Hi Gerald,
>> Regards,
>> Ebrahim Poorazizi
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org <mailto:Zoo-discuss at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss <http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss>
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20141127/55e4b7b2/attachment.html>
More information about the Zoo-discuss mailing list
