[Zoo-discuss] Zoo-project installation and running on Centos-6
Francesco Barchetta francesco.barchetta at terradue.com
Fri Dec 18 01:47:09 PST 2015
Hello!
In the context of our Earth Observation projects my company (Terradue UK) would like to adopt your implementation of WPS, .
The typical environment where to install the server is a VM with CentOS release 6.7 x86_64 .
INSTALLATION:
From the official documentation:
http://zoo-project.org/docs/install/centos.html
If I've tried to follow the list of commands I quickly found some issue or incorrect steps:
yum install apache2
do you mean httpd?
yum install build-essentials
do you mean yum groupinstall "Development Tools” ?
yum install gcc-c++
yum install libxml2-devel
yum install zlib-devel
yum install bison
yum install openssl
yum install python-devel
yum install subversion
Additional prerequisites found:
yum install libxslt-devel.x86_64
yum install libcurl-devel
yum install gdal-devel
yum install proj-devel.x86_64
yum install libuuid-devel
yum install openssl-devel
FOR GDAL 1.8.0 (otherwise zoo-kernel will complain about VSILFILE)
wget http://download.osgeo.org/gdal/gdal-1.8.0.tar.gz
tar xzf gdal-1.8.0.tar.gz
cd gdal-1.8.0
./configure  # add your options here
make
make install
TO INSTALL FASTCGI
wget http://www.fastcgi.com/dist/fcgi.tar.gz
tar xzf fcgi.tar.gz
cd fcgi-2.4.1-SNAP-0311112127/
PATCH (from http://stackoverflow.com/questions/4577453/fcgio-cpp50-error-eof-was-not-declared-in-this-scope):
	--- include/fcgio.h 2012-01-23 15:23:51.136063795 +0000
	+++ include/fcgio.h 2012-01-23 15:22:19.057221383 +0000
	@@ -31,6 +31,7 @@
 	#define FCGIO_H
	 #include <iostream>
	+#include <stdio.h>
	 #include "fcgiapp.h"
./configure
make
make install
echo /usr/local/lib >> /etc/ld.so.conf.d/local.conf
ldconfig
TO INSTALL autoconf tools (OK)
TO INSTALL FLEX TOOL (OK)
CURL:
To avoid the installation of a different version of Curl, I want to follow the guide about changing the file ulinet.c but the link to the code is broken and:
line 173 is :
printf("\n**[PROXY SETTINGS DETECTION %s (%d) %s:%li (%s)]**\n",proto,proxy_enabled,(char*)proxy_host,proxy_port,buffer);
line 175 is a white line
Should I comment these lines?
Anyway our base line version is 7.19.7. Is it good?
INSTALL ZOO-KERNEL
Since this section is totally missing I got inspiration from the previous version (still incomplete and not working):
http://www.zoo-project.org/docs/kernel/install-centos.html
svn co http://svn.zoo-project.org/svn/trunk zoo-project
cd zoo-project/thirds/cgic206
edit file Makefile in order to set the current fgci path adding:
	LIBS= -L./ -lcgic /usr/local/lib/libfcgi.so
make
cd ../../zoo-project/zoo-kernel
autoconf
./configure --with-java=/usr/java/jdk1.6.0_35/ --with-python --with-gdal_config=/usr/bin/gdal-config
make zoo_loader.cgi
make install
cp main.cfg /var/www/cgi-bin/
cp zoo_loader.cgi /var/www/cgi-bin/
In httpd.conf I have to add:
SetEnv LD_LIBRARY_PATH /usr/local/lib/
Now the GetCapabilities and DescribeProcess calls work fine.
EXECUTE:
HelloPy works fine.
HelloWorldJava is not working:
From the Browser => 500 Internal Server Error
Form the command line:
 ./zoo_loader.cgi "Service=WPS&request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Test"Content-Type: text/xml; charset=UTF-8
Status: 501 Internal Server Error
Segmentation fault
With gdb:
(gdb) run "Service=WPS&request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Test"
Starting program: /var/www/cgi-bin/zoo_loader.cgi "Service=WPS&request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Test"
[Thread debugging using libthread_db enabled]
[New Thread 0x7fffe7283700 (LWP 29445)]
[New Thread 0x7fffe7182700 (LWP 29446)]
[New Thread 0x7fffe6b8b700 (LWP 29447)]
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff500204a in frame::frame(long*, long*) () from /usr/java/jdk1.6.0_35/jre/lib/amd64/server/libjvm.so
CONCLUSIONS
I hope that my experience could help you to improve the installation procedure description and I hope you could help me to find out the reason of the failed execution.
Best Regards,
Francesco Barchetta
Terradue UK
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20151218/c0abafff/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20151218/c0abafff/attachment.bin>
More information about the Zoo-discuss mailing list
