[Zoo-discuss] Zoo-project installation and running on Centos-6
Fenoy Gerald gerald.fenoy at geolabs.fr
Fri Dec 18 03:32:29 PST 2015
Hello Francesco,
nice to hear that you are willing to adopt the ZOO-Project.
First of all, I have to say that this documentation has been written 5 years ago, so any help on setting up the ZOO-Project on CentOS is probably needed. The original version was there : [1].
For the package names I have to admit that I don’t have access to any CentOS host to verify the package names, so the correct names will help us to fix this part of the documentation.
For the parameters you added to your httpd.conf for LD_LIBRARY_PATH, I think it is not required. Nevertheless, you should need to run ldconfig after you setup your ZOO-Kernel (by running make install). This should probably solve your issue with GetCapabilities and DescribeProcess.
I suppose that there is no need anymore for removing any line from ulinet.c to get it working. I hope you can confirm this by executing services passing parameter by reference rather than by value.
For the issue when trying to Execute a Java service, I supposed that the issue came because you did not setup the ZOO-API Java Class. So I tried it locally but I have a standard Exception report returned in this case and it contains the following information: * Exception in thread "main" java.lang.NoClassDefFoundError: ZOO * . So there should be no problem here. Maybe it can help me if you can provide the back trace from gdb after the segfault.
I hope to hear back from you,
Best regards,
[1] http://zoo-project.org/trac/wiki/ZooDocumentation/ZOOKernel/CentOS_installation
> Le 18 déc. 2015 à 10:47, Francesco Barchetta <francesco.barchetta at terradue.com> a écrit :
> Hello!
> In the context of our Earth Observation projects my company (Terradue UK) would like to adopt your implementation of WPS, .
> The typical environment where to install the server is a VM with CentOS release 6.7 x86_64 .
> INSTALLATION:
> From the official documentation:
> http://zoo-project.org/docs/install/centos.html
> If I've tried to follow the list of commands I quickly found some issue or incorrect steps:
> yum install apache2
> do you mean httpd?
> yum install build-essentials
> do you mean yum groupinstall "Development Tools” ?
> yum install gcc-c++
> yum install libxml2-devel
> yum install zlib-devel
> yum install bison
> yum install openssl
> yum install python-devel
> yum install subversion
> Additional prerequisites found:
> yum install libxslt-devel.x86_64
> yum install libcurl-devel
> yum install gdal-devel
> yum install proj-devel.x86_64
> yum install libuuid-devel
> yum install openssl-devel
> FOR GDAL 1.8.0 (otherwise zoo-kernel will complain about VSILFILE)
> wget http://download.osgeo.org/gdal/gdal-1.8.0.tar.gz
> tar xzf gdal-1.8.0.tar.gz
> cd gdal-1.8.0
> ./configure  # add your options here
> make
> make install
> TO INSTALL FASTCGI
> wget http://www.fastcgi.com/dist/fcgi.tar.gz
> tar xzf fcgi.tar.gz
> cd fcgi-2.4.1-SNAP-0311112127/
> PATCH (from http://stackoverflow.com/questions/4577453/fcgio-cpp50-error-eof-was-not-declared-in-this-scope):
> 	--- include/fcgio.h 2012-01-23 15:23:51.136063795 +0000
> 	+++ include/fcgio.h 2012-01-23 15:22:19.057221383 +0000
> 	@@ -31,6 +31,7 @@
>  	#define FCGIO_H
> 	 #include <iostream>
> 	+#include <stdio.h>
> 	 #include "fcgiapp.h"
> ./configure
> make
> make install
> echo /usr/local/lib >> /etc/ld.so.conf.d/local.conf
> ldconfig
> TO INSTALL autoconf tools (OK)
> TO INSTALL FLEX TOOL (OK)
> CURL:
> To avoid the installation of a different version of Curl, I want to follow the guide about changing the file ulinet.c but the link to the code is broken and:
> line 173 is :
> printf("\n**[PROXY SETTINGS DETECTION %s (%d) %s:%li (%s)]**\n",proto,proxy_enabled,(char*)proxy_host,proxy_port,buffer);
> line 175 is a white line
> Should I comment these lines?
> Anyway our base line version is 7.19.7. Is it good?
> INSTALL ZOO-KERNEL
> Since this section is totally missing I got inspiration from the previous version (still incomplete and not working):
> http://www.zoo-project.org/docs/kernel/install-centos.html
> svn co http://svn.zoo-project.org/svn/trunk zoo-project
> cd zoo-project/thirds/cgic206
> edit file Makefile in order to set the current fgci path adding:
> 	LIBS= -L./ -lcgic /usr/local/lib/libfcgi.so
> make
> cd ../../zoo-project/zoo-kernel
> autoconf
> ./configure --with-java=/usr/java/jdk1.6.0_35/ --with-python --with-gdal_config=/usr/bin/gdal-config
> make zoo_loader.cgi
> make install
> cp main.cfg /var/www/cgi-bin/
> cp zoo_loader.cgi /var/www/cgi-bin/
> In httpd.conf I have to add:
> SetEnv LD_LIBRARY_PATH /usr/local/lib/
> Now the GetCapabilities and DescribeProcess calls work fine.
> EXECUTE:
> HelloPy works fine.
> HelloWorldJava is not working:
> From the Browser => 500 Internal Server Error
> Form the command line:
>  ./zoo_loader.cgi "Service=WPS&request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Test"Content-Type: text/xml; charset=UTF-8
> Status: 501 Internal Server Error
> Segmentation fault
> With gdb:
> (gdb) run "Service=WPS&request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Test"
> Starting program: /var/www/cgi-bin/zoo_loader.cgi "Service=WPS&request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Test"
> [Thread debugging using libthread_db enabled]
> [New Thread 0x7fffe7283700 (LWP 29445)]
> [New Thread 0x7fffe7182700 (LWP 29446)]
> [New Thread 0x7fffe6b8b700 (LWP 29447)]
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff500204a in frame::frame(long*, long*) () from /usr/java/jdk1.6.0_35/jre/lib/amd64/server/libjvm.so
> CONCLUSIONS
> I hope that my experience could help you to improve the installation procedure description and I hope you could help me to find out the reason of the failed execution.
> Best Regards,
> Francesco Barchetta
> Terradue UK
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
