[Zoo-discuss] ZOO 1.4 Java installation
Fenoy Gerald gerald.fenoy at geolabs.fr
Thu Mar 12 07:52:15 PDT 2015
Hi Alexander,
sorry for late reply.
I would like to invite you to try with the latest trunk version available from the SVN repository [1].
In rev. 611, the error messages mentioning the libjava were fixed and the « client » directory was renamed as « server ».
This should solve your issue in installing the Java Support.
Once this task is done, I invite you to take a look at the documentation on how to setup the Java ZOO-API [3].
Best regards,
[1] http://zoo-project.org/site/Downloads#Fordevelopers
[2] http://zoo-project.org/trac/changeset/611
[3] http://zoo-project.org/docs/services/howtos.html#java
> Le 12 mars 2015 à 12:55, Alexander Kmoch <alexander.kmoch at aut.ac.nz> a écrit :
> Hi all,
> I have downloaded the ZOO 1.4 release, and tried to compile and install on a Ubuntu 14.04 and a recent Arch Linux.
> Standard configure is fine, but the --with-java is not working for me on both distros.
> In the configure.ac there will be an error message pointing to a JDK_HOME (aka JAVA_HOME) but in the actual configure only JDKHOME will be honored. This is a type a presume. Ok, knowing that, the configure looks/mentions for libjava (although LDFLAGS is -ljvm) in <java home>/jre/lib/amd64/client
> This is a bit weird, because in neither the openjdk7 nor oracle-jdk7 have that folder. libjvm.so resides in  <java home>jre/lib/amd64/server/libjvm.so and libjava in <java home>/jre/lib/amd64/libjava.so (amd64 for my architecture of course)
> The directory layout is the same for openjdk7 and oracle-jdk7, there is no client folder. I tried to meddle around with the CPPFLAGS and LDFLAGS but haven't been successful yet. The includes work wenn JDKHOME (not JDK_HOME) env var is set properly to a JAVA_HOME (not a JRE_HOME) and ./configure --with-java=$JDKHOME
> Any ideas?
> Cheers,
> Alex
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
