[Zoo-discuss] ZOOGrassModuleStarter instance has no attribute 'logfile
pablo zader pzader at gmail.com
Sun May 3 12:13:21 PDT 2015
Hello Quang
If I change the directory owner to www-data, it works well. But it also
works if you have the permissions to 777 with user root.
For example
drwxrwxrwx  31 root root 12288 may  3 16:10 tmp
drwxrwxrwx 2 root     root        4096 may  3 16:07 /tmp/zoo
But my question is another:
"*There are two issues I want to raise:*
   1.
*best would return an error message: "Can not create the directory", rather
   than "ZOOGrassModuleStarter instance has no attribute 'logfile"??? (This is
   bug zoo-proyect??) *
   2.
*If my tmp is: drwxrwxrwx  30 root root 12288 may  3 00:43 tmp Why
   zoo-project can not create the directory zoo? *"
Thanks
2015-05-03 15:35 GMT-03:00 truongxuan quang <truongxuanquang at yahoo.com>:
> Hello Pablo
> Can you please change / tmp/zoo to www-data permission
> Quang
>   On Sunday, May 3, 2015 5:54 AM, pablo zader <pzader at gmail.com> wrote:
> Hi list
> I'm working with GRASS GIS services, particularly "r.what".
> Experiment a problem to define a nonexistent directory in GlobalGras
> Settings.py file:
> WORKDIR="/tmp/zoo"
> OUTPUTDIR="/tmp/zoo"
> LOGFILE="/tmp/zoo/logfile.txt"
> LOGFILE_MODULE_STDOUT="/tmp/zoo/logfile_module_stdout.txt"
> LOGFILE_MODULE_STDERR="/tmp/zoo/logfile_module_sterr.txt"
> GRASS_GIS_BASE="/home/pablo/grass_trunk/dist.x86_64-unknown-linux-gnu"
> GRASS_ADDON_PATH="/home/pablo/wps-grass-bridge/gms/Testing/Python/GrassAddons"
> GRASS_VERSION="7.0.svn"
> if the "/ tmp/zoo" directory does not exist, an error occurs:
> <ExceptionReport xmlns="http://www.opengis.net/ows/1.1" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" version="1.1.0">
> <Exception exceptionCode="NoApplicableCode">
> <ExceptionText>
> TRACE : ZOOGrassModuleStarter instance has no attribute 'logfile' <type
> 'exceptions.AttributeError'> Unable to run your python process properly.
> Please check the following messages : [' File "/usr/lib/cgi-bin/r_what.py",
> line 7, in r_what\n service.fromMaps("r.what", inputs, outputs)\n', ' File
> "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 43, in fromMaps\n
> self._createTemporalDir(GlobalGrassSettings.WORKDIR)\n', ' File
> "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 248, in
> _createTemporalDir\n self.LogError(log)\n', ' File
> "/usr/lib/cgi-bin/gms/ProcessLogging.py", line 70, in LogError\n
> self.logfile.write("\\n<ERROR timestamp=\\"" + localtime + "\\">\\n")\n']
> </ExceptionText>
> </Exception>
> </ExceptionReport>
>    1. best would return an error message: "Can not create the directory",
>    rather than "ZOOGrassModuleStarter instance has no attribute
>    'logfile"??? (This is bug zoo-proyect??)
>    2. If my tmp is:
>    Why zoo-project can not create the directory zoo?
> Thanks in advanced
> Pablo
> *Pablo J. Zader*
> *Lic. en Cs. de la Computación*
> *pablo.zader at gmail.com <pablo.zader at gmail.com>*
> *"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
> sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
> *del libro Matemática estas ahi? A. Paenza "*
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
*Pablo J. Zader*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20150503/62cf9493/attachment.html>
More information about the Zoo-discuss mailing list
