[Zoo-discuss] ZOOGrassModuleStarter instance has no attribute 'logfile
truongxuan quang truongxuanquang at yahoo.com
Sun May 3 13:18:46 PDT 2015
Dear Pablo
I am aslo ZOO-Project user, did you try  to set your configure file with /tmp/(without zoo)/...I think it works perfectly!
I don't  know which version you are using but as I google it in http://code.google.com/p/wps-grass-bridge/source/browse/trunk/ZOOGrassModuleStarter.py?r=9&spec=svn9 it looks something wrong with the path in configure file
Quang
     On Sunday, May 3, 2015 9:13 PM, pablo zader <pzader at gmail.com> wrote:
 Hello Quang
If I change the directory owner to www-data, it works well. But it also works if you have the permissions to 777 with user root.
For example
drwxrwxrwx  31 root root 12288 may  3 16:10 tmp
drwxrwxrwx 2 root     root        4096 may  3 16:07 /tmp/zoo
But my question is another:
"There are two issues I want to raise:
   - best would return an error message: "Can not create the directory", rather than "ZOOGrassModuleStarter instance has no attribute 'logfile"??? (This is bug zoo-proyect??)
   - If my tmp is:
drwxrwxrwx  30 root root 12288 may  3 00:43 tmp
Why zoo-project can not create the directory zoo? "
Thanks
2015-05-03 15:35 GMT-03:00 truongxuan quang <truongxuanquang at yahoo.com>:
Hello Pablo
Can you please change / tmp/zoo to www-data permission  Quang
     On Sunday, May 3, 2015 5:54 AM, pablo zader <pzader at gmail.com> wrote:
 Hi list
I'm working with GRASS GIS services, particularly "r.what".
Experiment a problem to define a nonexistent directory in GlobalGras Settings.py file:
WORKDIR="/tmp/zoo"OUTPUTDIR="/tmp/zoo"LOGFILE="/tmp/zoo/logfile.txt"LOGFILE_MODULE_STDOUT="/tmp/zoo/logfile_module_stdout.txt"LOGFILE_MODULE_STDERR="/tmp/zoo/logfile_module_sterr.txt"GRASS_GIS_BASE="/home/pablo/grass_trunk/dist.x86_64-unknown-linux-gnu"GRASS_ADDON_PATH="/home/pablo/wps-grass-bridge/gms/Testing/Python/GrassAddons"GRASS_VERSION="7.0.svn"
if the "/ tmp/zoo" directory does not exist, an error occurs:
 <ExceptionReportxmlns="http://www.opengis.net/ows/1.1"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"xsi:schemaLocation="http://www.opengis.net/ows/1.1http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"xml:lang="en-US" version="1.1.0">
<ExceptionexceptionCode="NoApplicableCode">
<ExceptionText>
TRACE: ZOOGrassModuleStarter instance has no attribute 'logfile' <type'exceptions.AttributeError'> Unable to run your python processproperly. Please check the following messages : [' File"/usr/lib/cgi-bin/r_what.py", line 7, in r_what\nservice.fromMaps("r.what", inputs, outputs)\n', ' File"/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 43, infromMaps\n self._createTemporalDir(GlobalGrassSettings.WORKDIR)\n', 'File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line248, in _createTemporalDir\n self.LogError(log)\n', ' File"/usr/lib/cgi-bin/gms/ProcessLogging.py", line 70, inLogError\n self.logfile.write("\\n<ERROR timestamp=\\""+ localtime + "\\">\\n")\n']
</ExceptionText>
</Exception>
</ExceptionReport>
   - best would return an error message: "Can not create the directory", rather than "ZOOGrassModuleStarterinstance has no attribute 'logfile"??? (This is bug zoo-proyect??)
   - If my tmp is:
Thanks in advanced
Pablo
Pablo J. ZaderLic. en Cs. de la Computaciónpablo.zader at gmail.com
"Los Grandes Hombres hablan sobre ideas...
 Los Hombres Promedio hablan sobre cosas...
 Los Hombres Pequeños hablan.. de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
Zoo-discuss mailing list
Zoo-discuss at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20150503/5a6eb70a/attachment-0001.html>
More information about the Zoo-discuss mailing list
