[Zoo-discuss] ZOOGrassModuleStarter instance has no attribute 'logfile
pablo zader pzader at gmail.com
Sun May 3 14:05:43 PDT 2015
Dear Quang
Yes, like this here "
http://code.google.com/p/wps-grass-bridge/source/browse/trunk/ZOOGrassModuleStarter.py?r=9&spec=svn9"
 works perfectly, but if you look right there mentioned, If I want  I
changue the path.
Turning again to my original question if that path there and if you forgot
create, the service will not work! and  error message to return ZOO does
not refer to this error, it is not clear.
# !!!!! EDIT THIS SECTION !!!!!
# Some default variables. Override them to your needs. *<---- HERE*
WORKDIR="/tmp"
OUTPUTDIR="/tmp"
LOGFILE="logfile.txt"
LOGFILE_MODULE_STDOUT="logfile_module_stdout.txt"
LOGFILE_MODULE_STDERR="logfile_module_sterr.txt"
GRASS_GIS_BASE=
"/home/soeren/src/grass7.0/grass_trunk/dist.i686-pc-linux-gnu"
GRASS_ADDON_PATH=
"/home/soeren/src/vtkGRASSBridge/vtk-grass-bridge/WPS/Testing/Python/GrassAddons"
GRASS_VERSION="7.0.svn"
# !!!!! END EDIT SECTION !!!!!
Pablo
2015-05-03 17:18 GMT-03:00 truongxuan quang <truongxuanquang at yahoo.com>:
> Dear Pablo
> I am aslo ZOO-Project user, did you try  to set your configure file with
> /tmp/(without zoo)/...
> I think it works perfectly!
> I don't  know which version you are using but as I google it in
> http://code.google.com/p/wps-grass-bridge/source/browse/trunk/ZOOGrassModuleStarter.py?r=9&spec=svn9 it
> looks something wrong with the path in configure file
> Quang
>   On Sunday, May 3, 2015 9:13 PM, pablo zader <pzader at gmail.com> wrote:
> Hello Quang
> If I change the directory owner to www-data, it works well. But it also
> works if you have the permissions to 777 with user root.
> For example
> drwxrwxrwx  31 root root 12288 may  3 16:10 tmp
> drwxrwxrwx 2 root     root        4096 may  3 16:07 /tmp/zoo
> But my question is another:
> "*There are two issues I want to raise:*
>    1.
> *best would return an error message: "Can not create the directory",
>    rather than "ZOOGrassModuleStarter instance has no attribute 'logfile"???
>    (This is bug zoo-proyect??) *
>    2.
> *If my tmp is: drwxrwxrwx  30 root root 12288 may  3 00:43 tmp Why
>    zoo-project can not create the directory zoo? *"
> Thanks
> 2015-05-03 15:35 GMT-03:00 truongxuan quang <truongxuanquang at yahoo.com>:
> Hello Pablo
> Can you please change / tmp/zoo to www-data permission
> Quang
>   On Sunday, May 3, 2015 5:54 AM, pablo zader <pzader at gmail.com> wrote:
> Hi list
> I'm working with GRASS GIS services, particularly "r.what".
> Experiment a problem to define a nonexistent directory in GlobalGras
> Settings.py file:
> WORKDIR="/tmp/zoo"
> OUTPUTDIR="/tmp/zoo"
> LOGFILE="/tmp/zoo/logfile.txt"
> LOGFILE_MODULE_STDOUT="/tmp/zoo/logfile_module_stdout.txt"
> LOGFILE_MODULE_STDERR="/tmp/zoo/logfile_module_sterr.txt"
> GRASS_GIS_BASE="/home/pablo/grass_trunk/dist.x86_64-unknown-linux-gnu"
> GRASS_ADDON_PATH="/home/pablo/wps-grass-bridge/gms/Testing/Python/GrassAddons"
> if the "/ tmp/zoo" directory does not exist, an error occurs:
> <ExceptionReport xmlns="http://www.opengis.net/ows/1.1" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" version="1.1.0">
> <Exception exceptionCode="NoApplicableCode">
> <ExceptionText>
> TRACE : ZOOGrassModuleStarter instance has no attribute 'logfile' <type
> 'exceptions.AttributeError'> Unable to run your python process properly.
> Please check the following messages : [' File "/usr/lib/cgi-bin/r_what.py",
> line 7, in r_what\n service.fromMaps("r.what", inputs, outputs)\n', ' File
> "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 43, in fromMaps\n
> self._createTemporalDir(GlobalGrassSettings.WORKDIR)\n', ' File
> "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 248, in
> _createTemporalDir\n self.LogError(log)\n', ' File
> "/usr/lib/cgi-bin/gms/ProcessLogging.py", line 70, in LogError\n
> self.logfile.write("\\n<ERROR timestamp=\\"" + localtime + "\\">\\n")\n']
> </ExceptionText>
> </Exception>
> </ExceptionReport>
>    1. best would return an error message: "Can not create the directory",
>    'logfile"??? (This is bug zoo-proyect??)
>    2. If my tmp is:
>    Why zoo-project can not create the directory zoo?
> Thanks in advanced
> Pablo
> *Pablo J. Zader*
> *Lic. en Cs. de la Computación*
> *pablo.zader at gmail.com <pablo.zader at gmail.com>*
> *"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
> sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
> *del libro Matemática estas ahi? A. Paenza "*
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> *Pablo J. Zader*
*Pablo J. Zader*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20150503/cd0b91a3/attachment.html>
More information about the Zoo-discuss mailing list
