[Zoo-discuss] Building kernel with Java support
rakesh prithiviraj rakeshuk at outlook.com
Wed Apr 27 07:01:57 PDT 2016
I am trying to build zoo-kernel with Java support on 64 bit Ubuntu machine.
/configure --with-js --with-python --with-java=/usr/lib/jvm/java-7-openjdk-amd64/
"http://www.zoo-project.org/docs/install/installation.html#java-support-optional" assumes that the include/linux and jre/lib/i386/client/ subdirectories exist in /usr/lib/jvm/java-7-openjdk-amd64/, and that the include/linux directory contains the jni.h headers file and that the jre/lib/i386/client/ directory contains the libjvm.so file.
As I am using OpenJDK (and not Oracle Java), 1. "include/linux" has 2 files (jawt_md.h, jni_md.h) and not jni.h asabove assumption2. libjvm.so is located under /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/ (it is not under jre/lib/i386/client/ as assumed by configure option).
The configure command did not throw any errors. Last few lines from console output are given below
checking jni.h usability... yeschecking jni.h presence... yeschecking for jni.h... yeschecking for JNI_CreateJavaVM in -ljvm... yesconfigure: creating ./config.statusconfig.status: creating Makefileconfig.status: creating ZOOMakefile.opts
Trying to access the Kernel CGI via Apache2 server did not work and apache logs shows the following error.
[Wed Apr 27 14:16:27.015884 2016] [cgi:error] [pid 16337:tid 140125807777536] [client 193.128.33.248:12614] AH01215: /usr/lib/cgi-bin/zoo_loader.cgi: error while loading shared libraries: libjvm.so: cannot open shared object file: No such file or directory[Wed Apr 27 14:16:27.015950 2016] [cgi:error] [pid 16337:tid 140125807777536] [client 193.128.33.248:12614] End of script output before headers: zoo_loader.cgi
Also shared library dependencies command confirmed that ldd zoo_loader.cgi | grep jvm        libjvm.so => not found
Java is in the PATH as seen below.
$locate libjvm.so/usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so$echo $JAVA_HOME/usr/lib/jvm/java-7-openjdk-amd64/bin$echo $JDK_HOME/usr/lib/jvm/java-7-openjdk-amd64/ Please let me know if there a way to tell .configure command the path to libjvm.
regardsRakesh
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160427/774972aa/attachment.html>
More information about the Zoo-discuss mailing list
