[Zoo-discuss] File libzoo_service.so.1.5 doesn't get installed
Fenoy Gerald gerald.fenoy at geolabs.fr
Tue Dec 13 00:30:25 PST 2016
Dear Jacinto,
once you have run the make install, then you should have everything setup correctly.
Nevertheless, if the libzoo_service.so is not found, it means that the location of the library (probably /usr/local/lib) is not in the search PATH, you may check in /etc/ld.so.conf or in /etc/ld.so.conf.d (depending on your Linux distribution). In other case, it may also come from the ldconfig tool that should be run to update and take into account new PATH added to the library path (LD_LIBRARY_PATH if I recall well).
I hope this helps you to solve your issue.
Best regards,
> Le 13 déc. 2016 à 09:06, Jacinto Estima <jacinto.estima at gmail.com> a écrit :
> Dear list,
> I am new to the ZOO project.
> I was trying to install it in UBUNTU 16.04 32 bit running on a virtualbox virtual machine.
> I followed all the instructions available at http://www.zoo-project.org/docs/install/debian.html but when a do "sudo make install" inside zoo-kernel, the file libzoo_service.so.1.5 doesn't get installed. The files libzoo_service.so and zoo_loader.cgi are there. I did all the remaining steps and when I tried to access the GetCapabilities I got the following error in the apache error log:
> [Tue Dec 13 11:39:51.543837 2016] [cgi:error] [pid 5892] [client 127.0.0.1:38330] AH01215: /usr/lib/cgi-bin/zoo_loader.cgi: error while loading shared libraries: libzoo_service.so.1.5: cannot open shared object file: No such file or directory: /usr/lib/cgi-bin/zoo_loader.cgi
> Anyone that could help me figure this out?
> Thank you very much,
> Jacinto
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
