[Zoo-discuss] File libzoo_service.so.1.5 doesn't get installed
Jacinto Estima jacinto.estima at gmail.com
Tue Dec 13 02:43:43 PST 2016
Dear Gérald,
Thank you for your prompt reply.
When you say that the library is not in the search PATH, did you mean the
$PATH env variable?
Thanks,
Jacinto
On Tue, 13 Dec 2016 at 12:30 Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
> Dear Jacinto,
> once you have run the make install, then you should have everything setup
> correctly.
> Nevertheless, if the libzoo_service.so is not found, it means that the
> location of the library (probably /usr/local/lib) is not in the search
> PATH, you may check in /etc/ld.so.conf or in /etc/ld.so.conf.d (depending
> on your Linux distribution). In other case, it may also come from the
> ldconfig tool that should be run to update and take into account new PATH
> added to the library path (LD_LIBRARY_PATH if I recall well).
> I hope this helps you to solve your issue.
> Best regards,
> > Le 13 déc. 2016 à 09:06, Jacinto Estima <jacinto.estima at gmail.com> a
> écrit :
> > Dear list,
> > I am new to the ZOO project.
> > I was trying to install it in UBUNTU 16.04 32 bit running on a
> virtualbox virtual machine.
> > I followed all the instructions available at
> http://www.zoo-project.org/docs/install/debian.html but when a do "sudo
> make install" inside zoo-kernel, the file libzoo_service.so.1.5 doesn't get
> installed. The files libzoo_service.so and zoo_loader.cgi are there. I did
> all the remaining steps and when I tried to access the GetCapabilities I
> got the following error in the apache error log:
> > [Tue Dec 13 11:39:51.543837 2016] [cgi:error] [pid 5892] [client
> 127.0.0.1:38330] AH01215: /usr/lib/cgi-bin/zoo_loader.cgi: error while
> loading shared libraries: libzoo_service.so.1.5: cannot open shared object
> file: No such file or directory: /usr/lib/cgi-bin/zoo_loader.cgi
> > Anyone that could help me figure this out?
> > Thank you very much,
> > Jacinto
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20161213/8d922773/attachment.html>
More information about the Zoo-discuss mailing list
