[Zoo-discuss] File libzoo_service.so.1.5 doesn't get installed
Johan Van de Wauw johan.vandewauw at gmail.com
Tue Dec 13 02:50:56 PST 2016
No,
Check eg: http://stackoverflow.com/questions/17889799/libraries-in-usr-local-lib-not-found
Kind Regards,
Johan
On Tue, Dec 13, 2016 at 11:43 AM, Jacinto Estima
<jacinto.estima at gmail.com> wrote:
> Dear Gérald,
> Thank you for your prompt reply.
> When you say that the library is not in the search PATH, did you mean the
> $PATH env variable?
> Thanks,
> Jacinto
> On Tue, 13 Dec 2016 at 12:30 Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
>> Dear Jacinto,
>> once you have run the make install, then you should have everything setup
>> correctly.
>> Nevertheless, if the libzoo_service.so is not found, it means that the
>> location of the library (probably /usr/local/lib) is not in the search PATH,
>> you may check in /etc/ld.so.conf or in /etc/ld.so.conf.d (depending on your
>> Linux distribution). In other case, it may also come from the ldconfig tool
>> that should be run to update and take into account new PATH added to the
>> library path (LD_LIBRARY_PATH if I recall well).
>> I hope this helps you to solve your issue.
>> Best regards,
>> > Le 13 déc. 2016 à 09:06, Jacinto Estima <jacinto.estima at gmail.com> a
>> > écrit :
>> > Dear list,
>> > I am new to the ZOO project.
>> > I was trying to install it in UBUNTU 16.04 32 bit running on a
>> > virtualbox virtual machine.
>> > I followed all the instructions available at
>> > http://www.zoo-project.org/docs/install/debian.html but when a do "sudo make
>> > install" inside zoo-kernel, the file libzoo_service.so.1.5 doesn't get
>> > installed. The files libzoo_service.so and zoo_loader.cgi are there. I did
>> > all the remaining steps and when I tried to access the GetCapabilities I got
>> > the following error in the apache error log:
>> > [Tue Dec 13 11:39:51.543837 2016] [cgi:error] [pid 5892] [client
>> > 127.0.0.1:38330] AH01215: /usr/lib/cgi-bin/zoo_loader.cgi: error while
>> > loading shared libraries: libzoo_service.so.1.5: cannot open shared object
>> > file: No such file or directory: /usr/lib/cgi-bin/zoo_loader.cgi
>> > Anyone that could help me figure this out?
>> > Thank you very much,
>> > Jacinto
>> > _______________________________________________
>> > Zoo-discuss mailing list
>> > Zoo-discuss at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
>> Gérald Fenoy
>> http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
