[Zoo-discuss] File libzoo_service.so.1.5 doesn't get installed
Jacinto Estima jacinto.estima at gmail.com
Tue Dec 13 03:28:35 PST 2016
Thank you both. It worked. I was missing the command *ldconfig *after
adding the path.
Thank you again,
Jacinto
On Tue, 13 Dec 2016 at 14:51 Johan Van de Wauw <johan.vandewauw at gmail.com>
wrote:
> No,
> Check eg:
> http://stackoverflow.com/questions/17889799/libraries-in-usr-local-lib-not-found
> Kind Regards,
> Johan
> On Tue, Dec 13, 2016 at 11:43 AM, Jacinto Estima
> <jacinto.estima at gmail.com> wrote:
> > Dear Gérald,
> > Thank you for your prompt reply.
> > When you say that the library is not in the search PATH, did you mean the
> > $PATH env variable?
> > Thanks,
> > Jacinto
> > On Tue, 13 Dec 2016 at 12:30 Fenoy Gerald <gerald.fenoy at geolabs.fr>
> wrote:
> >> Dear Jacinto,
> >> once you have run the make install, then you should have everything
> setup
> >> correctly.
> >> Nevertheless, if the libzoo_service.so is not found, it means that the
> >> location of the library (probably /usr/local/lib) is not in the search
> PATH,
> >> you may check in /etc/ld.so.conf or in /etc/ld.so.conf.d (depending on
> your
> >> Linux distribution). In other case, it may also come from the ldconfig
> tool
> >> that should be run to update and take into account new PATH added to the
> >> library path (LD_LIBRARY_PATH if I recall well).
> >> I hope this helps you to solve your issue.
> >> Best regards,
> >> > Le 13 déc. 2016 à 09:06, Jacinto Estima <jacinto.estima at gmail.com> a
> >> > écrit :
> >> > Dear list,
> >> > I am new to the ZOO project.
> >> > I was trying to install it in UBUNTU 16.04 32 bit running on a
> >> > virtualbox virtual machine.
> >> > I followed all the instructions available at
> >> > http://www.zoo-project.org/docs/install/debian.html but when a do
> "sudo make
> >> > install" inside zoo-kernel, the file libzoo_service.so.1.5 doesn't get
> >> > installed. The files libzoo_service.so and zoo_loader.cgi are there.
> I did
> >> > all the remaining steps and when I tried to access the
> GetCapabilities I got
> >> > the following error in the apache error log:
> >> > [Tue Dec 13 11:39:51.543837 2016] [cgi:error] [pid 5892] [client
> >> > 127.0.0.1:38330] AH01215: /usr/lib/cgi-bin/zoo_loader.cgi: error
> while
> >> > loading shared libraries: libzoo_service.so.1.5: cannot open shared
> object
> >> > file: No such file or directory: /usr/lib/cgi-bin/zoo_loader.cgi
> >> > Anyone that could help me figure this out?
> >> > Thank you very much,
> >> > Jacinto
> >> > _______________________________________________
> >> > Zoo-discuss mailing list
> >> > Zoo-discuss at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> >> Gérald Fenoy
> >> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20161213/5604f7bc/attachment-0001.html>
More information about the Zoo-discuss mailing list
