[Zoo-discuss] Install Mapmint
Fenoy Gerald gerald.fenoy at geolabs.fr
Wed Jan 20 12:31:25 PST 2016
Dear Chingchai,
nice to hear that you are trying to install the MapMint product on your platform.
For your first point, there is probably something wrong in the way the database is defined in the main.cfg file or configuration of the database server itself.
For your second point, it seems that the directory to store sessions is not defined or pointing to a non existing directory, or it can also be an issue with privileges to write in this directory.
So we should dig into details about the specific failure to solve them.
In other case, I personally think it is the preferred way, you may use the Ansible scripts we published on github [1] to install MapMint. The script do every single step that I tried to describe earlier in the INSTALL.md file (the one you used). From now, you may refer to the following documentation [2] (the source is also available on github [3]) to setup MapMint with only few command lines.
I hope you can give the Ansible scripts a try and give feedbacks to us.
Best regards,
[1] https://github.com/mapmint/ansible-roles
[2] http://zoo-project.org/mm/userguide-fr/_build/html/introduction/installmapmint.html
[3] https://github.com/mapmint/userguide-fr
> Le 20 janv. 2016 à 03:27, chingchai humhong <chingchai.h at gmail.com> a écrit :
> Dear All,
> I'm master student of Dr.Sittichai Choosumrong (Bomp)'s laboratory at Naresuan University, Thailand. I also used to met and discussed with Prof.Venkatesh about MapMint. So, I interested on MapMint and start learning some month ago.
> recently, I've learned MapMint software,
> I'm trying to install mapmint from github[1]
> I have two problem during set up mapmint.
> 1. When access login mapmint using id test and the password is demo02 through url: http://127.0.0.1/ui/Dashboard_bs/. see the picture from this link[2]
> I had problem massage alert Unable to run the Service. The message returned back by the Service was the following: Unable to connect to the User Database.
> 2.When access mapmint through url: http://127.0.0.1/ui/public/ I had problem with service.py. see the picture from this link[3]
> <ows:ExceptionReport xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd" xml:lang="fr-FR" version="1.1.0">
> 	<ows:Exception exceptionCode="NoApplicableCode">
> 		<ows:ExceptionText>
> 			TRACE: ('senv',)
> 			<type 'exceptions.KeyError'>Unable to run your python process properly. Please check the following messages :
> 			['  File "/home/eileen/src/mapmint/mapmint-services/template/service.py", line 114, in display\n    conf[\'senv\'][\'last_map\']="Georeferencer"\n']
> 		</ows:ExceptionText>
> 	</ows:Exception>
> </ows:ExceptionReport>
> Best regards,
> Chingchai
> [1] https://github.com/mapmint/mapmint/blob/master/INSTALL.md
> [2] https://drive.google.com/a/nu.ac.th/file/d/0B6Fk2noS6wzNZjNFTkJoNzhfZTA/view
> [3] https://drive.google.com/a/nu.ac.th/file/d/0B6Fk2noS6wzNUHVFa3o4bFkySU0/view
> Chingchai  Humhong
> Regional Center of Geo-Informatics and
> Space Technology, Lower Northern Region
> Naresuan University Phitsanulok 65000
> Lat:16.742496, Lon:100.191605
> Map: http://maps.googleapis.com/maps/api/staticmap?center=16.742496,100.191605&zoom=14&size=400x400&sensor=false
> Mobile: 08-4624-6278
> Blog: http://nu-gis.blogspot.com
> Website: http://www.cgistln.nu.ac.th
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
