[Zoo-discuss] Changing behaviour for mandatory input
Fenoy Gerald gerald.fenoy at geolabs.fr
Tue May 31 01:19:37 PDT 2016
Dear Rakesh,
I was able to reproduce with the revision 764 the same behavior. But now I don’t have any issue.
The GetStatus request now returns: <wps:Status>Failed</wps:Status> and GetResult returns an ExceptionReport.
So, first I would like to you make sure you have run make clean then make and make install.
In case it still occurs after that, I would like you to check the content of the files created in your tmpPath (defined in your main.cfg file) and containing the JobId in their name. Report their content here, in case it is of any help.
If you have activated the dbBackend please let me know, I made the test without using it but I have faced the same issue before so I thought you did not activated the db backend but I may be wrong.
I hope to hear back from you,
Best regards,
> Le 30 mai 2016 à 22:14, rakesh prithiviraj <rakeshuk at outlook.com> a écrit :
> Hi Gerald,
> I checked out rev 765, compiled, installed ZOO kernel. But I still observe the same behaviour.
> regards
> Rakesh
> > Subject: Re: [Zoo-discuss] Changing behaviour for mandatory input
> > From: gerald.fenoy at geolabs.fr
> > Date: Mon, 30 May 2016 19:14:55 +0200
> > CC: zoo-discuss at lists.osgeo.org
> > To: rakeshuk at outlook.com
> > Hi,
> > thanks for your feedbacks.
> > It should be considerate as a bug indeed. Please can you try the same scenario using the revision 765 please ?
> > I hope to hear back from you and this new revision solves your issue.
> > Best regards,
> > > Le 30 mai 2016 à 18:08, rakesh prithiviraj <rakeshuk at outlook.com> a écrit :
> > > Hi,
> > > If the WPS execute request does not contain mandatory input(s), then the response of the ZOO-Kernel depends on the mode of execution: async or sync.
> > > For example: DataInputs section of myService.zcfg contains 2 inputs called "i1" and "i2" each of which has minOccurs field set to 1.
> > > If my WPS execute request mode is set to sync (mode="sync") and if I miss to specify input i2, then I get the following exception as WPS execute response
> > > <ows:ExceptionText>The <i2> argument was not specified in DataInputs but is required according to the ZOO ServicesProvider configuration file.</ows:ExceptionText>
> > > But if I change the mode to async ( mode="async") and if I miss to specify input i2, then I do not get any exception but following responses:
> > > 1. <wps:StatusInfo>
> > > <wps:JobID>7f4bfe7a-2680-11e6-9741-005056011a8c</wps:JobID>
> > > <wps:Status>Accepted</wps:Status>
> > > 2. <wps:GetResult
> > > <ows:ExceptionText>The result for the requested JobID has not yet been generated. </ows:ExceptionText>
> > > 3. <wps:JobID>7f4bfe7a-2680-11e6-9741-005056011a8c</wps:JobID>
> > > <wps:Status>Running</wps:Status>
> > > Is this a possible bug?
> > > regards
> > > Rakesh
> > > _______________________________________________
> > > Zoo-discuss mailing list
> > > Zoo-discuss at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> > Gérald Fenoy
> > http://wiki.osgeo.org/wiki/User:Djay
Gérald Fenoy
More information about the Zoo-discuss mailing list
