[Zoo-discuss] Zoo compatible with libcgic 2.0.7?
Fenoy Gerald gerald.fenoy at geolabs.fr
Mon Sep 5 23:57:14 PDT 2016
Hello,
sorry for coming back so late.
In fact I gave the cgic207 a try the day you have sent this message but did not reply after.
The biggest issue seems to come from the fact that cgic207 cannot be used from C++ code. Note that it may also come from the fact that I don’t know how to use it from C++ code. Nevertheless, it was probably the reason why we created our own copy of this library.
For the functions I want to use from the cgic207 library they will need to be defined as extern « C » when they are currently only declared as extern.
I have tried using extern « c » { #include « cgic.h » } but did not solve the issue.
In case we can have any information about the specific issue we have then we may try to solve it.
So by now I would say that we are not supporting cgic207.
I hope to have some input about this issue.
Best regards,
> Le 1 sept. 2016 à 11:59, Fenoy Gerald <gerald.fenoy at geolabs.fr> a écrit :
> Dear Johan,
> we use a special version cgic library. Nevertheless, it is only required when you build the ZOO-Kernel. Afterward there is no need anymore for this library. So I think it should not hurt for creating ZOO-Project packages.
> I will try to use this cgic207 and report before next monday. In case you have any news until that, please report your results.
> Best regards,
>> Le 31 août 2016 à 11:02, Johan Van de Wauw <johan.vandewauw at gmail.com> a écrit :
>> Hello,
>> Currently the debian and ubuntu versions of zoo project ship with a version of libcgic (2.0.6) which is newer than the version in the official archives (2.0.5).
>> I was planning to update Debian and ubuntu so they will contain a newer release of libcgic so the custom library is no longer needed. I prefer upgrading to version 2.0.7 available at [1].
>> Has anyone tested this version with zoo?
>> Kind Regards,
>> Johan
>> [1] http://www.boutell.com/cgic/cgic207.tar.gz
>> Zoo-discuss mailing list
>> Zoo-discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
Gérald Fenoy
More information about the Zoo-discuss mailing list
