[Zoo-discuss] ZOO-Project OGC API - Processes User Interface
Luca Delucchi lucadeluge at gmail.com
Fri Nov 6 04:21:59 PST 2020
On Fri, 6 Nov 2020 at 10:07, GĂ©rald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> Dear Luca,
> Thanks a lot for your message.
> Note that I have deployed few services but did not test all of the services. Thanks for your report about issue with vector-tools.Buffer service.
> In case you try the same using the vector-tools.BufferPy alternative it is working properly.
> You can find here [1] the result of the execution using the vector-tools.BufferPy with your JSON data as input.
> I hope you can confirm that using the *Py alternative works also on your side.
Yes it seems to work, but I'm not able to find the results, could you
please tell me the steps, I copied the "Id"
(6a62821c-2032-11eb-b16b-525400a77789) after I submitted but I'm not
understanding how to see the status and results
> Best regards,
thanks
ciao
Luca
www.lucadelu.org
More information about the Zoo-discuss mailing list
