[Zoo-discuss] ZOO-Project OGC API - Processes User Interface
Venka venka.osgeo at gmail.com
Fri Nov 6 19:16:25 PST 2020
Hi Gerald,
Thanks for the update and all you work
on the OGC API support for ZOO-Project.
Look forward to these enhancements in the
next ZOO-Project release.
Best
Venka
On 11/6/2020 9:52 PM, Gérald Fenoy wrote:
> Luca,
> I am not sure of where you find the id you are referring to. In case it is the one automatically set in callbacks URIs then it is not the identifier for the job itself but for the id used in redis to keep track of the ongoing status.
> After configuring your form, preferably setting the Result as application/json format for being able to show the result properly (the default xml output format will imply addition of blocks not supported in the current HTML display, using a textarea in place of the pre one to show the result should solve this issue, setting Result transmission parameter to reference solves also this HTML display issue anyway). Once you click on the « Submit job » button from the modal showing you JSON Request, your browser will subscribe to redis through WebSocket and will show loading bar (with so small data, you won’t probably be able to see anything as the service will be executed quickly) after the execution is over, you will see the JSON result displayed just bellow the textarea showing the JSON Request.
> Note that you can also have a look at the job list for your Service (vector-tools.BufferPy) from here [1] to find your service and check the JSON status/result if any or even delete your execution using the delete tool.
> I hope it clarifies the situation and you can confirm that you can use it with the informations provided in this email.
> Best regards,
> [1] https://demo.mapmint.com/ogc-api/processes/vector-tools.BufferPy/jobs.html
> Gerald Fenoy
> Chair, ZOO-Project PSC
>> Le 6 nov. 2020 à 13:21, Luca Delucchi <lucadeluge at gmail.com> a écrit :
>> On Fri, 6 Nov 2020 at 10:07, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
>>> Dear Luca,
>>> Thanks a lot for your message.
>>> Note that I have deployed few services but did not test all of the services. Thanks for your report about issue with vector-tools.Buffer service.
>>> In case you try the same using the vector-tools.BufferPy alternative it is working properly.
>>> You can find here [1] the result of the execution using the vector-tools.BufferPy with your JSON data as input.
>>> I hope you can confirm that using the *Py alternative works also on your side.
>> Yes it seems to work, but I'm not able to find the results, could you
>> please tell me the steps, I copied the "Id"
>> (6a62821c-2032-11eb-b16b-525400a77789) after I submitted but I'm not
>> understanding how to see the status and results
>>> Best regards,
>> thanks
>> ciao
>> Luca
>> www.lucadelu.org
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
