[ZOO-PSC] ZOO-Project 2.0.0 release
nicolas bozon nicolas.bozon at gmail.com
Tue Feb 13 09:10:45 PST 2024
+1 Nick
Le mar. 13 févr. 2024 à 18:08, Gérald Fenoy via ZOO-PSC <
zoo-psc at lists.osgeo.org> a écrit :
> Dear PSC members,
> I intend to request your support in voting to release the ZOO-Project's
> 2.0.0 release candidate version.
> There were some years since the last release.
> Also, we need to renew the OGC-certified compliance license(s) for the
> ZOO-Project product on February 19.
> So, I think it is perfect timing to release a new version and get it
> certified.
> We tested on a local setup and the ZOO-Project passed 100% of the tests
> for both OGC API - Processes - Part 1: Core and synchronous WPS 2.0.
> Below, you can see a list of significant modifications:
>   * Update relation type to monitor for the status location.
>   * Add support for the conformance class remote processes from the
>   OGC API - Processes - Part 3: Workflow & chaining. Execution of
>   remote processes are automatically run asynchronously in case the
>   root process was invoked asynchronously.
>   * Parse the Location header from ulinet and the cookie if any.
>   * Add schemas to the components and support description stored in the
> file.
>   * Add a trivial DeployOnHpc service for automating the installation
>   and the deployment of a singularity container using the image
>   parameter provided in the executionUnit used when deploying the
>   process.
>   * Set the key json_response_object with the JSON response that the
>   ZOO-Kernel produced for the request, it can be updated from a
>   filter_out process.
>   * Update filter_in to support returning a response directly by
>   adding a response key in the lenv section (binary is supported for
>   this response)
>   * Provide an initial Dockefile dedicated to the DRU support with
>   remote HPC execution support
>   * Add a USE_HPC_NESTEDOUTPUTS build option to activate the nested
>   inputs and outputs addition (not supported with OGC API - Processes
>   - Part 1: Core)
>   * Update C-API errorException and printExceptionResponse* signatures
>   to handle the main configuration maps memory properly
>   *  Build Docker image with DRU supporting OpenEO UDP encoding
>   * Add support for deploying and executing OpenEO User Defined
>   Processes by using an OpenEO graph for the executionUnit
>   * Add support for schema type string for request body, providing a
>   way to include CWL example files in the published OpenAPI
>   * Integrate the OGC API - Processes - Part 2: Deploy, Replace,
>   Undeploy optional support.
>   * Build Docker image based on MDL4EO/OTBTF and the onnx runtime for
>   models sharing
>   * Integrate the TeamEngine and ETS for OGC API - Processes
>   * Add JWT parser in security_service.py as filter_in to allocate
>   resources per authenticated user
>   * Integrate the work done during GSoC 2022 to support Node.js
>   ZOO-Services (cf. updated documentation for NodeJS)
>   * Update support to filter the jobs list using the user_id
>   * Add support for nested processes n OGC API - Processes - Part 3:
>   Workflows & Chaining
>   * Add filter_in and filter_out service array to be invoked previously
>   of and after the service run
>   * Add trivial support for OpenAPI security, basicAuth / openId, and add
>   sample services implementation
>   * Add support for MapServer 8.0 (actually 7.7-dev), including
>   returning result as OGC API -Features
>   * Integrate downloading MapServer 8.0 and building from the
>   dedicated Dockerfile-MS8
>   * Include basicAuth build instructions in the Dockefile
>   * Add basicAuth service illustrating how to secure access to OGC API
>   - Processes using Basic Authentication
>   * Use the osecurity section to detect secured path, request method
>   from the published OpenAPI
>   * Update the printHeaders function to allow Status definition at runtime
>   * Add a [osecurity] section to secure access to path, method couple
>   * Update the database connection handling to make it independent from
>   instantiation order
>   * Use the RabbitMQ also for OGC API - Processes
>   * Pass the subscriber if any is passed from the original request
>   * Make C OGR base-vect-ops compatible with memory=protect
>   * Add volumes to be shared by the ZOO-Kernel and the ZOO-FPM
>   * Add a RabbitMQ and a ZOO-FPM container to docker-compose
>   * Add documentation for RabbitMQ support and ZOO Fast Process
>   Manager (ZOO-FPM)
>   * Optional use of ZOO-Kernel Fast Process Manager backends to handle
>   asynchronous execution
>   * Partial integration of the code from the
>   Publicamundi_David_integration01-devel branch
> I propose myself as a release manager, and the release is to occur this
> coming Saturday (2024/02/17).
> My vote is +1 for this release to happen as proposed.
> Best regards,
> Gerald Fenoy
> gerald.fenoy at geolabs.fr
> Chair, ZOO-Project PSC
> ZOO-PSC mailing list
> ZOO-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-psc
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20240213/b1f61d72/attachment-0001.htm>
More information about the ZOO-PSC mailing list
