[ZOO-PSC] ZOO-Project 2.0.0 release
Venkatesh Raghavan raghavan at omu.ac.jp
Tue Feb 13 14:13:27 PST 2024
+1
Venka
On 2/14/2024 2:43 AM, Maria Antonia Brovelli via ZOO-PSC wrote:
> +1
> Maria
> Inviato da Outlook per Android<https://aka.ms/AAb9ysg>
> ________________________________
> From: ZOO-PSC <zoo-psc-bounces at lists.osgeo.org> on behalf of Angelos Tzotsos via ZOO-PSC <zoo-psc at lists.osgeo.org>
> Sent: Tuesday, February 13, 2024 6:09:27 PM
> To: Gérald Fenoy <gerald.fenoy at geolabs.fr>
> Cc: zoo-psc <zoo-psc at lists.osgeo.org>
> Subject: Re: [ZOO-PSC] ZOO-Project 2.0.0 release
> +1
> Angelos
> On Tue, Feb 13, 2024 at 7:08 PM Gérald Fenoy via ZOO-PSC <zoo-psc at lists.osgeo.org<mailto:zoo-psc at lists.osgeo.org>> wrote:
> Dear PSC members,
> I intend to request your support in voting to release the ZOO-Project's 2.0.0 release candidate version.
> There were some years since the last release.
> Also, we need to renew the OGC-certified compliance license(s) for the ZOO-Project product on February 19.
> So, I think it is perfect timing to release a new version and get it certified.
> We tested on a local setup and the ZOO-Project passed 100% of the tests for both OGC API - Processes - Part 1: Core and synchronous WPS 2.0.
> Below, you can see a list of significant modifications:
>    * Update relation type to monitor for the status location.
>    * Add support for the conformance class remote processes from the
>    OGC API - Processes - Part 3: Workflow & chaining. Execution of
>    remote processes are automatically run asynchronously in case the
>    root process was invoked asynchronously.
>    * Parse the Location header from ulinet and the cookie if any.
>    * Add schemas to the components and support description stored in the file.
>    * Add a trivial DeployOnHpc service for automating the installation
>    and the deployment of a singularity container using the image
>    parameter provided in the executionUnit used when deploying the
>    process.
>    * Set the key json_response_object with the JSON response that the
>    ZOO-Kernel produced for the request, it can be updated from a
>    filter_out process.
>    * Update filter_in to support returning a response directly by
>    adding a response key in the lenv section (binary is supported for
>    this response)
>    * Provide an initial Dockefile dedicated to the DRU support with
>    remote HPC execution support
>    * Add a USE_HPC_NESTEDOUTPUTS build option to activate the nested
>    inputs and outputs addition (not supported with OGC API - Processes
>    - Part 1: Core)
>    * Update C-API errorException and printExceptionResponse* signatures
>    to handle the main configuration maps memory properly
>    *  Build Docker image with DRU supporting OpenEO UDP encoding
>    * Add support for deploying and executing OpenEO User Defined
>    Processes by using an OpenEO graph for the executionUnit
>    * Add support for schema type string for request body, providing a
>    way to include CWL example files in the published OpenAPI
>    * Integrate the OGC API - Processes - Part 2: Deploy, Replace,
>    Undeploy optional support.
>    * Build Docker image based on MDL4EO/OTBTF and the onnx runtime for
>    models sharing
>    * Integrate the TeamEngine and ETS for OGC API - Processes
>    * Add JWT parser in security_service.py as filter_in to allocate
>    resources per authenticated user
>    * Integrate the work done during GSoC 2022 to support Node.js
>    ZOO-Services (cf. updated documentation for NodeJS)
>    * Update support to filter the jobs list using the user_id
>    * Add support for nested processes n OGC API - Processes - Part 3:
>    Workflows & Chaining
>    * Add filter_in and filter_out service array to be invoked previously
>    of and after the service run
>    * Add trivial support for OpenAPI security, basicAuth / openId, and add
>    sample services implementation
>    * Add support for MapServer 8.0 (actually 7.7-dev), including
>    returning result as OGC API -Features
>    * Integrate downloading MapServer 8.0 and building from the
>    dedicated Dockerfile-MS8
>    * Include basicAuth build instructions in the Dockefile
>    * Add basicAuth service illustrating how to secure access to OGC API
>    - Processes using Basic Authentication
>    * Use the osecurity section to detect secured path, request method
>    from the published OpenAPI
>    * Update the printHeaders function to allow Status definition at runtime
>    * Add a [osecurity] section to secure access to path, method couple
>    * Update the database connection handling to make it independent from
>    instantiation order
>    * Use the RabbitMQ also for OGC API - Processes
>    * Pass the subscriber if any is passed from the original request
>    * Make C OGR base-vect-ops compatible with memory=protect
>    * Add volumes to be shared by the ZOO-Kernel and the ZOO-FPM
>    * Add a RabbitMQ and a ZOO-FPM container to docker-compose
>    * Add documentation for RabbitMQ support and ZOO Fast Process
>    Manager (ZOO-FPM)
>    * Optional use of ZOO-Kernel Fast Process Manager backends to handle
>    asynchronous execution
>    * Partial integration of the code from the
>    Publicamundi_David_integration01-devel branch
> I propose myself as a release manager, and the release is to occur this coming Saturday (2024/02/17).
> My vote is +1 for this release to happen as proposed.
> Best regards,
> Gerald Fenoy
> gerald.fenoy at geolabs.fr<mailto:gerald.fenoy at geolabs.fr>
> Chair, ZOO-Project PSC
> ZOO-PSC mailing list
> ZOO-PSC at lists.osgeo.org<mailto:ZOO-PSC at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/zoo-psc
> Angelos Tzotsos, PhD
> President, Board of Directors
> Open Source Geospatial Foundation
> http://users.ntua.gr/tzotsos
More information about the ZOO-PSC mailing list
