[Aust-NZ] FOSS4G Conf Logo (text)
Shaun Kolomeitz
Shaun.Kolomeitz at epa.qld.gov.au
Wed Jun 4 20:44:39 EDT 2008
(Refer to the previously scrubbed email for the JPG image)
OK. I'll admit right now - I can't draw for nuts ! but thought about
something like the following
(Following on from Cape Towns Table Mountain line theme) -
A stylised line drawing of a bounding Kangaroo (an Aboriginal dot style
would be better I think)
(The Kangaroo is unmistakably Australian)
the Harbour bridge (obviously Sydney)
And the FOSS4G ribbon somewhere with "FOSS4G 2009" on the bottom.
(I like the idea of using Aboriginal dot styles as this is the year on
conciliation, even though next year isn't).
I've also seen a nice logo with the harbour bridge running diagonally
across the image.
(I stuffed up the year in my scribble)
What do people think ?
Cheers,
Shaun
Think B4U Print
1 ream of paper = 6% of a tree and 5.4kg CO2 in the atmosphere
3 sheets of A4 paper = 1 litre of water
_________________________
Disclaimer
WARNING: This e-mail (including any attachments) has originated from a Queensland Government department and may contain information that is confidential, private, or covered by legal professional privilege, and may be protected by copyright.
You may use this e-mail only if you are the person(s) it was intended to be sent to and if you use it in an authorised way. No one is allowed to use, review, alter, transmit, disclose, distribute, print or copy this e-mail without appropriate authority. If you have received this e-mail in error, please inform the sender immediately by phone or e-mail and delete this e-mail, including any copies, from your computer system network and destroy any hardcopies.
Unless otherwise stated, this e-mail represents the views of the sender and not the views of the Environmental Protection Agency.
Although this e-mail has been checked for the presence of computer viruses, the Environmental Protection Agency provides no warranty that all viruses have been detected and cleaned. Any use of this e-mail could harm your computer system. It is your responsibility to ensure that this e-mail does not contain and is not affected by computer viruses, defects or interference by third parties or replication problems (including incompatibility with your computer system).
E-mails sent to and from the Environmental Protection Agency will be electronically stored, managed and may be audited, in accordance with the law and Queensland Government Information Standards (IS31, IS38, IS40, IS41 and IS42) to the extent they are consistent with the law.
___________________________
!DEPTSTAMP1!
More information about the Aust-NZ
