[Aust-NZ] RE: FOSS4G Conference Logo
Cameron Shorter
cameron.shorter at gmail.com
Wed Jun 4 21:32:26 EDT 2008
I like the idea of tying Aboriginal painting styles and colours into the
diagram.
Good idea with the ribbon too.
Shaun Kolomeitz wrote:
> OK. I’ll admit right now - I can’t draw for nuts ! but thought about
> something like the following
> (Following on from Cape Towns Table Mountain line theme) –
> A stylised line drawing of a bounding Kangaroo (an Aboriginal dot
> style would be better I think)
> (The Kangaroo is unmistakably Australian)
> the Harbour bridge (obviously Sydney)
> And the FOSS4G ribbon somewhere with “FOSS4G 2009” on the bottom.
> (I like the idea of using Aboriginal dot styles as this is the year on
> conciliation, even though next year isn’t).
> I’ve also seen a nice logo with the harbour bridge running diagonally
> across the image.
> (I stuffed up the year in my scribble)
> What do people think ?
> Cheers,**
> *Shaun*
> Think B4U Print
> 1 ream of paper = 6% of a tree and 5.4kg CO2 in the atmosphere
> 3 sheets of A4 paper = 1 litre of water
> ___________________________
> Disclaimer
> WARNING: This e-mail (including any attachments) has originated from a
> Queensland Government department and may contain information that is
> confidential, private, or covered by legal professional privilege, and
> may be protected by copyright.
> You may use this e-mail only if you are the person(s) it was intended
> to be sent to and if you use it in an authorised way. No one is
> allowed to use, review, alter, transmit, disclose, distribute, print
> or copy this e-mail without appropriate authority. If you have
> received this e-mail in error, please inform the sender immediately by
> phone or e-mail and delete this e-mail, including any copies, from
> your computer system network and destroy any hardcopies.
> Unless otherwise stated, this e-mail represents the views of the
> sender and not the views of the Environmental Protection Agency.
> Although this e-mail has been checked for the presence of computer
> viruses, the Environmental Protection Agency provides no warranty that
> all viruses have been detected and cleaned. Any use of this e-mail
> could harm your computer system. It is your responsibility to ensure
> that this e-mail does not contain and is not affected by computer
> viruses, defects or interference by third parties or replication
> problems (including incompatibility with your computer system).
> E-mails sent to and from the Environmental Protection Agency will be
> electronically stored, managed and may be audited, in accordance with
> the law and Queensland Government Information Standards (IS31, IS38,
> IS40, IS41 and IS42) to the extent they are consistent with the law.
> !DEPTSTAMP1!
> Aust-NZ mailing list
> Aust-NZ at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/aust-nz
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Aust-NZ
