[Aust-NZ] Re: [GeoNetwork-devel] Why do we have a Bluenet branch of
Geonetwork?
Simon Pigot
Simon.Pigot at csiro.au
Thu Jun 5 05:28:25 EDT 2008
Cameron Shorter wrote:
> I understand that we have a Bluenet branch of Geonetwork.
> There are some good reasons for maintaining multiple branches, but it
> comes with a significant maintenance cost.
> I'm wondering what the reasons are for maintaining the Bluenet MEST
> branch separately to the trunk and whether it would be possible to merge
> these branches together, possibly by tweaking our software development
> processes.
> Eg, if we have a separate branch for stability reasons, maybe we have a
> business case to spend effort on automated testing procedures.
Apart from historical reasons (see earlier posts) and the normal process
of developing and testing in your own branch, there is no agreed method
for supporting profiles of standards (as opposed to different standards)
in GN, and in BlueNet there isn't a clean separation (yet) between the
code and facilities that support profiles and the rest of GeoNetwork.
In the short term I think this could be addressed by:
1. Getting the existing methods for supporting profiles of standards (as
used in BlueNet and possibly for the Inspire work - Francois?) -
merged, approved by the PSC and into the GeoNetwork trunk.
2. Consolidating as much as possible profile specific information in the
appropriate profile directory eg.
web/geonetwork/xml/schemas/iso19139.mcp - this includes presentation and
conversion xsls and various other things (like templates and sample
data) that are still spread around the install directory :-).
3. Bundle up national profiles as optional installation packages (to be
supplied with the GN release?) - responsibility for the installation
packages to be handed to maintainer(s).
In the long term, an architecture that would allow dynamic plugin of a
profile would be good but for the moment I think the above would go some
way to allowing more people to contribute to the development process on
trunk. If the fact that the national profile is on a branch is an
impediment to GeoNetwork continuing as the Australian Government
Metadata Entry Tool (OSDM) and the ANZLIC Metadata Entry Tool (ANZLIC
metadata project), then this should help.
The rest of the perception about the BlueNet branch is (to me) the usual
tension that happens when development gets a bit far away from the trunk
and needs to be sync'd.
Cheers,
Simon
More information about the Aust-NZ
