[Aust-NZ] Re: [Geodata] Australian Census Data?
Cameron Shorter cameron.shorter at gmail.com
Mon Jun 23 19:27:45 EDT 2008
Nathan,
As far as I'm aware, there is no free Australian map data in the
quality you are looking for.
You might want to look at getting data from the Open Street Map
project which might be complete enough for your needs. (It is still
patchy).
Others on the Aust-NZ list might be able to suggest an alternative.
Alternatively, you might want to look at buying access to the data as
a Web Map Service or similar from a company like
http://terrapages.com.au (Apology for commercial plug - Terrapages is
LISAsoft's sister company. I can put you in touch with a sales rep if
interested).
On Mon, Jun 23, 2008 at 10:09 PM, Nathan Gerber <ngerber999 at gmail.com> wrote:
> Hello all,
> I am programming a project for a company in Australia that involves web
> mapping and I was wondering if there was a freely available data format I
> could convert for the needs of this project. What I'm looking for is
> province boundaries, roads, and possibly streams which I could convert to a
> shape file format for use with Mapserver.
> Nathan Gerber
> Geodata mailing list
> Geodata at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geodata
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Aust-NZ mailing list
